Writing in a PDF form
Old 24-09-2008, 2:13 PM   #1
6,523, Level: 19
Points: 6,523, Level: 19 Points: 6,523, Level: 19 Points: 6,523, Level: 19
Thanks: Gave 192, Got 97
I've just downloaded a banking form in PDF format and there are four pages of details to fill out on this one and another two on the next - any way I can open it up so as to fill out the information on the computer and then print it out?
Old 24-09-2008, 2:15 PM   #2
11,419, Level: 25
Points: 11,419, Level: 25 Points: 11,419, Level: 25 Points: 11,419, Level: 25
Activity: 7.6%
Activity: 7.6% Activity: 7.6% Activity: 7.6%
Thanks: Gave 9, Got 49
Re: Writing in a PDF form
You can open them in Microsfot Word well im sure you could in the 2003 versioin 2007 needs a add-on tho.
Astraeus (24-09-2008)
Old 24-09-2008, 2:17 PM   #3
Iccz's Avatar
29,842, Level: 42
Points: 29,842, Level: 42 Points: 29,842, Level: 42 Points: 29,842, Level: 42
Activity: 33.7%
Activity: 33.7% Activity: 33.7% Activity: 33.7%
Thanks: Gave 3,753, Got 4,287
Yeah you need to convert PDF to whatever you want to use to edit it, then use that to edit/print, or then save as a PDF.
Unless you go for a PDF editing app, there are some out there, not sure there are free/good ones though.
Old 24-09-2008, 3:26 PM   #4
Illustrious Member
sdb123's Avatar
31,232, Level: 43
Points: 31,232, Level: 43 Points: 31,232, Level: 43 Points: 31,232, Level: 43
Thanks: Gave 1,578, Got 2,031
cutepdf is a pretty good pdf freebie on the net
Old 24-09-2008, 4:09 PM   #5
IronGiant's Avatar
25,161, Level: 38
Points: 25,161, Level: 38 Points: 25,161, Level: 38 Points: 25,161, Level: 38
Activity: 34.1%
Activity: 34.1% Activity: 34.1% Activity: 34.1%
Thanks: Gave 2,331, Got 4,980
another cute vote
Old 24-09-2008, 9:45 PM   #6
Illustrious Member
Rasczak's Avatar
57,897, Level: 58
Points: 57,897, Level: 58 Points: 57,897, Level: 58 Points: 57,897, Level: 58
Activity: 8.3%
Activity: 8.3% Activity: 8.3% Activity: 8.3%
Thanks: Gave 689, Got 898
Pretty obvious but have you just tried clicking on the fields you want to fill in? In my experience normally if a company gives you a PDF form to complete digitally it has data entry enabled.
Old 24-09-2008, 10:09 PM   #7
Conspicuous Member
16,150, Level: 30
Points: 16,150, Level: 30 Points: 16,150, Level: 30 Points: 16,150, Level: 30
Activity: 11.0%
Activity: 11.0% Activity: 11.0% Activity: 11.0%
Thanks: Gave 1,238, Got 919
Was just going to say the same, can't you simply click in the fields, Adobe has supported internal active fields for some time now.
