Sparky? Please explain
Old 22-09-2008, 7:38 PM   #1
11,435, Level: 25
Points: 11,435, Level: 25 Points: 11,435, Level: 25 Points: 11,435, Level: 25
Activity: 7.1%
Activity: 7.1% Activity: 7.1% Activity: 7.1%
Thanks: Gave 10, Got 50
Can a sparky explain what the council have done to my fuse board?
My house is starting to be rewired and I know the fuse box will be replaced when finished and the old white meter heating box removed What is this stuff they have added
Old 22-09-2008, 7:51 PM   #2
drummerjohn's Avatar
8,486, Level: 22
Points: 8,486, Level: 22 Points: 8,486, Level: 22 Points: 8,486, Level: 22
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 58, Got 131
Re: Sparky? Please explain
They have replaced what would have been a 60\80\100 amp fuse connected to the meter with a switch. Allows for easier maintenane of new consumer unit.
The have added a neutral block and an earth block. These 3 things allow for possible expansion in the future ie 2 consumer units.
Hope that helps.
bouncer (22-09-2008)
Old 22-09-2008, 8:16 PM   #3
9,165, Level: 22
Points: 9,165, Level: 22 Points: 9,165, Level: 22 Points: 9,165, Level: 22
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 217, Got 360
What's going on with that cartridge board? Is that currently live? Or was that a "work in progress" picture...... it looks like a death trap....
Old 22-09-2008, 8:25 PM   #4
11,435, Level: 25
Activity: 7.1%
Oh the old fuse box that was proablly fitted when the house was built?
Thats AFTER they cut stuff out of it!!! A whole lot of stuff was ripped out of there and a few minior things replaced, They are going to remove that and fit a new box for all the new electicals in a few days.
Old 22-09-2008, 8:39 PM   #5
9,165, Level: 22
Activity: 3.0%
Usually when you cut a circuit out, you remove the associated cabling from the fuseboard, so it doesn't flap about next to the live circuits..... at least it's being replaced, looks like a good thing!
