SDS Drills
Old 06-09-2008, 7:24 PM   #1
danmc_82's Avatar
8,048, Level: 21
Points: 8,048, Level: 21 Points: 8,048, Level: 21 Points: 8,048, Level: 21
Thanks: Gave 934, Got 373
SDS Drills
Ive got a £60 sds drill which Ive been using for knocking out brickwork. Its been
good up until now (hammer action bust) so im after a new one.
Im a big fan of Makita stuff but what can you guys recommend.
Ive seen all the Makita stuff (compliments also welcome)so what else can catch my eye? Budget up to £150.
Old 06-09-2008, 8:27 PM   #2
sore napper's Avatar
6,219, Level: 18
Points: 6,219, Level: 18 Points: 6,219, Level: 18 Points: 6,219, Level: 18
Thanks: Gave 159, Got 251
Re: SDS Drills
I would go for Dewalt or Bosch ( should get one of these for a decent price and they do the trick).
danmc_82 (07-09-2008)
Old 06-09-2008, 9:00 PM   #3
danmc_82's Avatar
8,048, Level: 21
Re: SDS Drills
Why just them?
Old 06-09-2008, 10:08 PM   #4
15,816, Level: 30
Points: 15,816, Level: 30 Points: 15,816, Level: 30 Points: 15,816, Level: 30
Thanks: Gave 583, Got 289
Re: SDS Drills
Two of my mates got SDS drills from CPC for around £30. One, an electrician absolutely abuses his and it's still going strong four years later.Only issue he had was it needed brushes replaced - the drill came with a set of brushes anyway.
It even came with drills and chisels.
If you want i can find out the model and rating (iirc it's around 850w).
Edit:I've a feeling it might be this one...http://cpc.farnell.com/TL10748/tools...-power-npek850
It's current equivalent appears to be...http://www.nutool.co.uk/ProductOverv...rodID=NTPR1010
Old 06-09-2008, 10:21 PM   #5
2,542, Level: 11
Points: 2,542, Level: 11 Points: 2,542, Level: 11 Points: 2,542, Level: 11
Thanks: Gave 7, Got 79
Re: SDS Drills
I've got the 240v version of this one:
http://www.screwfix.com/prods/84014/...s-Hammer-Drill
Used it for all of the chasing (with a channelling chisel) and drilling when I rewired my house and it easily coped with that.
When using it to drill holes into masonry it's like a knife through butter.
Old 06-09-2008, 10:26 PM   #6
GasDad's Avatar
4,990, Level: 16
Points: 4,990, Level: 16 Points: 4,990, Level: 16 Points: 4,990, Level: 16
Thanks: Gave 1,508, Got 722
Re: SDS Drills
I'll second that recommendation - it gets abused, loaned to mates who are 'having problems with a hole' etc - and it's still going strong 4 years later.
Sometimes you can be lucky with cheaper power tools - but because they are made to slacker tolerances, it is down to luck - if you get one where all the bits line up, it will last years, otherwise months.
Old 06-09-2008, 11:57 PM   #7
Baron Von Doom's Avatar
7,103, Level: 20
Points: 7,103, Level: 20 Points: 7,103, Level: 20 Points: 7,103, Level: 20
Thanks: Gave 188, Got 62
Re: SDS Drills
Id recommend Makita or Bosch. I work in a power tool and hire shop.
A lot better after sales service and repairs. Anything we cant repair ourselves Makita usually get done within a week. In my experiance Dewalt/Black and Decker can take a lot longer.
We have a lot less trouble with Makita and Bosch.
Take a look at an HR2470 or the older 2450
http://www.screwfix.com/prods/99908/...SDS-Plus-Drill
Old 07-09-2008, 4:37 AM   #8
danmc_82's Avatar
8,048, Level: 21
Re: SDS Drills
Its very similar o the one ive got. It was great when I first got it but its like what "James Day" has said, you can get lucky with cheaper drills. Obviously I was not.
Old 07-09-2008, 4:38 AM   #9
danmc_82's Avatar
8,048, Level: 21
Re: SDS Drills
I think I will stick to one of the two you mentioned. ANy models you could recommend?
Old 07-09-2008, 10:02 AM   #10
Phil57's Avatar
3,204, Level: 13
Points: 3,204, Level: 13 Points: 3,204, Level: 13 Points: 3,204, Level: 13
Thanks: Gave 600, Got 310
Re: SDS Drills
Several posters are recommending SDS+ drills, that is not the same as SDS drills.
Old 07-09-2008, 10:07 AM   #11
7,103, Level: 20
Re: SDS Drills
Either
http://www.screwfix.com/prods/73560/...DS-Plus-Drill#
or
SDS covers sds+ or sds max. I assumed the op was talking about sds+
Old 07-09-2008, 11:14 AM   #12
4,039, Level: 14
Points: 4,039, Level: 14 Points: 4,039, Level: 14 Points: 4,039, Level: 14
Thanks: Gave 32, Got 130
Re: SDS Drills
I've found Ryobi to be high quality, affordable power tools.
Old 07-09-2008, 11:28 AM   #13
4,707, Level: 16
Points: 4,707, Level: 16 Points: 4,707, Level: 16 Points: 4,707, Level: 16
Thanks: Gave 153, Got 61
Re: SDS Drills
in my experience and those of tradesmen i know/use - DeWalt is an overpriced Black And Decker
most favour Makita - fabulous after sales service (not often needed)
my friend runs a large joinery 'shop' and on site joiners - he would not allow a DeWalt product to be bought let alone brought into the shop - Makita all the way
and its not his money he's spending so he gets no kickback/discount!
Old 07-09-2008, 1:31 PM   #14
6,219, Level: 18
Re: SDS Drills
Originally Posted by danmc_82 View Post
Why just them?
Well its not just them, but both of these seem to take quite a bit of abuse.
As someone has said, "DeWalt is an overpriced Black And Decker". I used to think that but the work van got broke into years ago and all the power tools where stolen. I got a good deal on a lot of De-Walt tools from a wholesaler and found them more than good enough for the job. The brushes needed changing every so often, but that only goes to prove that the drill was doing a lot of work and still going.
Brushes are cheap and easy to replace.
I don't see any point in buying anything too expensive as a good drop can break the tool.
There isn't anything wrong with Makita tools. Haven't bought one in awhile though, but I always found them to be very heavy and sometimes difficult to work with if in a tight spot, but a good brand non the less.
Old 07-09-2008, 3:13 PM   #15
danmc_82's Avatar
8,048, Level: 21
Re: SDS Drills
Thankyou all for your response.
Whats differance between SDS & SDS+?
Old 07-09-2008, 3:24 PM   #16
7,103, Level: 20
Re: SDS Drills
Different size sds+ is smaller than sds max. The drills and others of the same size i linked to are sds+. The larger type are usually used on heavier hand held breakers.
Old 07-09-2008, 3:25 PM   #17
IronGiant's Avatar
25,158, Level: 38
Points: 25,158, Level: 38 Points: 25,158, Level: 38 Points: 25,158, Level: 38
Activity: 33.7%
Activity: 33.7% Activity: 33.7% Activity: 33.7%
Thanks: Gave 2,330, Got 4,979
Re: SDS Drills
With SDS you can turn the hammer off, but not the drill, so you can't use it as a chiselling machine. SDS+ allows you to switch off the drill and use the hammer action only. They both take the same drill fittings. NB: I think...
I've had a cheap Wickes one for about 7 years with no problems but it hasn't been heavily used.
Dave
Edit: and as Coombes says, SDS Max are bigger fittings
Old 07-09-2008, 4:25 PM   #18
danmc_82's Avatar
8,048, Level: 21
Re: SDS Drills
Cheers, it was SDS+ Im after. Im leaning towards the Makita at the mo. Hitachi make some good stuff to but theres never any comments on them.
Old 07-09-2008, 4:30 PM   #19
7,103, Level: 20
Re: SDS Drills
Ive sold a few Hitachi power tools. Seem good quality. Ive not had any back yet. A few people dont like the bright green colour
Old 07-09-2008, 5:07 PM   #20
IronGiant's Avatar
25,158, Level: 38
Activity: 33.7%
Re: SDS Drills
Don't worry about the colour too much, they all turn brick dust orange or brieze block grey
Old 08-09-2008, 8:12 PM   #21
danmc_82's Avatar
8,048, Level: 21
Re: SDS Drills
I went for the Mikita HR2470 in the end. Got it for a good price of £95.
Old 08-09-2008, 8:16 PM   #22
7,103, Level: 20
Re: SDS Drills
Good choice and a good price
danmc_82 (08-09-2008)
