Dummies guide to Quidco...
Old 06-09-2008, 11:03 AM   #1
15,816, Level: 30
Points: 15,816, Level: 30 Points: 15,816, Level: 30 Points: 15,816, Level: 30
Thanks: Gave 583, Got 289
Can someone explain how i recieve cash from Quidco. I applied for a credit card which would result in a £41 payment to quidco.It's showing as £41 received in my earnings activity...how do i get this transferred to my bank?
£0.00 from * received on 20/06/2008
£41.00 from * received on 20/06/2008
£0.00 from * tracked on 04/01/2008
£41.00 from * tracked on 04/01/2008
Latest payment
No payments made
The Jan transaction was attributed to incorrect bank account details - the details supplied were correct though.
Old 06-09-2008, 11:20 AM   #2
WibXL's Avatar
6,038, Level: 18
Points: 6,038, Level: 18 Points: 6,038, Level: 18 Points: 6,038, Level: 18
Thanks: Gave 293, Got 383
Re: Dummies guide to Quidco...
It should be automatically sent to either a bank account or a paypal account once a month. Depends on which you setup.
EDIT: I think that you can also set it up to hold payments totally or until a certain amount is reached so if you've already setup where you want the payments to be sent that would be something else to check.
lynx (06-09-2008)
Old 06-09-2008, 11:31 AM   #3
Beetlejuice's Avatar
9,034, Level: 22
Points: 9,034, Level: 22 Points: 9,034, Level: 22 Points: 9,034, Level: 22
Thanks: Gave 1,034, Got 862
This should help, it's the 'Payments' help section
Old 06-09-2008, 11:40 AM   #4
Conspicuous Member
nheather's Avatar
17,661, Level: 32
Points: 17,661, Level: 32 Points: 17,661, Level: 32 Points: 17,661, Level: 32
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 595, Got 1,168
When you set up a Quidco account, the payment method is not setup automatically.
You need to go into your Quidco account and set up a method - either PayPal or BACS (Bank Transfer) as I recall.
Think they do a payment run once per month. Think there is a limit on how much they will pay in each month to PayPal. No limit on BACS.
Cheers,
Nigel
lynx (06-09-2008)
Old 06-09-2008, 11:54 AM   #5
15,816, Level: 30
BACS was the selected method when i set the account up, however no payments appear pending.
Strange.
Old 06-09-2008, 12:13 PM   #6
CooperUK's Avatar
5,060, Level: 16
Points: 5,060, Level: 16 Points: 5,060, Level: 16 Points: 5,060, Level: 16
Thanks: Gave 203, Got 89
It can take a while to go from received to payment made. Check in your earnings and see if the date on the right hand side gives an indication of when it might be.
lynx (06-09-2008)
Old 06-09-2008, 10:04 PM   #7
1,852, Level: 10
Points: 1,852, Level: 10 Points: 1,852, Level: 10 Points: 1,852, Level: 10
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 0, Got 26
If you have set up BACS correctly(including putting in bank details,a friend of mine forgot to do this) then Quidco asks you for a minimum amount to be paid on the 1st of each month,i`m just wondering what the default is -i can`t remember.Mine is set for a minimum payment of £20 with all payments going to my slush account.
lynx (06-09-2008)
Old 06-09-2008, 10:19 PM   #8
Steven's Avatar
61,727, Level: 60
Points: 61,727, Level: 60 Points: 61,727, Level: 60 Points: 61,727, Level: 60
Activity: 37.9%
Activity: 37.9% Activity: 37.9% Activity: 37.9%
Thanks: Gave 2,014, Got 4,411
They pay it at the start of the next calendar month, no doubt earning interest whilst you wait
Once you have received payment, and the money in your account is at the sufficient minimum earning amount that you have set, you should be able to see it under "future/pending payments" (cannot remember the term)
P.S. It goes from
tracked > validated > received > paid
Only in the last column does payment kick in. Its a couple of months ride!
