Possible house extension, timber frame structure?
Old 06-09-2008, 10:42 AM   #1
emporer's Avatar
12,296, Level: 26
Points: 12,296, Level: 26 Points: 12,296, Level: 26 Points: 12,296, Level: 26
Activity: 20.1%
Activity: 20.1% Activity: 20.1% Activity: 20.1%
Thanks: Gave 1,325, Got 1,232
We are in the process of a disabled facilities grant for work on our house due to our son being severly disabled, the main thing is the extension. Its either going to be a single storey extension at the rear of the house or built on top of our existing utility room thus extending the lads bedroom/bathroom. The people dealing with it have said they have started using timber frame constructions in cases like this, never heard of this before but they tell me the lifespan of such building would be around 40 years but require a bit more maintenance.
Anybody have experience of these constructions? I kind of like the idea but the wife aint that keen.
Old 06-09-2008, 2:13 PM   #2
16,091, Level: 30
Points: 16,091, Level: 30 Points: 16,091, Level: 30 Points: 16,091, Level: 30
Thanks: Gave 38, Got 205
Re: Possible house extension, timber frame structure?
I don't know much from a construction point of view but most mortgage companies won't touch anything timber-framed so that's worth bearing in mind.
Old 06-09-2008, 2:44 PM   #3
emporer's Avatar
12,296, Level: 26
Activity: 20.1%
Ive been reading stuff onkline with regards to timber framed extensions etc and it seems as though mortgage and insurance companies class them as permanent structures and have no problem with them, apparantly 20% of all houses in the UK are of this type now and increasing all the time.
Old 06-09-2008, 2:51 PM   #4
neilios's Avatar
3,548, Level: 13
Points: 3,548, Level: 13 Points: 3,548, Level: 13 Points: 3,548, Level: 13
Thanks: Gave 756, Got 398
I've just finished installing a disabled suite and rads for a customer and he had the extension built from the same materials as his house eg stone ,to match his building .
Old 06-09-2008, 2:57 PM   #5
GasDad's Avatar
4,991, Level: 16
Points: 4,991, Level: 16 Points: 4,991, Level: 16 Points: 4,991, Level: 16
Thanks: Gave 1,508, Got 722
What a ludicrous statement. Timber frame probably represents the majority of new house builds in the UK (well it did before they stopped building any houses a couple of months ago).
Old 06-09-2008, 5:14 PM   #6
Phil57's Avatar
3,205, Level: 13
Points: 3,205, Level: 13 Points: 3,205, Level: 13 Points: 3,205, Level: 13
Thanks: Gave 600, Got 310
What total nonsense.
Old 06-09-2008, 5:58 PM   #7
9,281, Level: 23
Points: 9,281, Level: 23 Points: 9,281, Level: 23 Points: 9,281, Level: 23
Thanks: Gave 38, Got 65
Have it brick and thermo block built, if the company does not do it right you wil have a load of problems, condensation, mold, rot, the building must be able to breath and thats where the skill is.
Old 06-09-2008, 6:09 PM   #8
Conspicuous Member
shahedz's Avatar
13,120, Level: 27
Points: 13,120, Level: 27 Points: 13,120, Level: 27 Points: 13,120, Level: 27
Thanks: Gave 1,382, Got 722
recently had an extension built. Instead of brick and breeze block, i had the big bricks ( looks like breeze block but is stronger ) - this saved me £2500 off the cost of the extension. All the walls went up in one days instead of a few days that traditional bricks can take, and also these bricks were cheaper. As the back of the existing house was rendered i had the extension rendered to fit and looks great!
Old 06-09-2008, 6:14 PM   #9
GasDad's Avatar
4,991, Level: 16
Err why? - timber framed, is almost certainly quicker, warmer, cheaper and produces less C02.
Old 06-09-2008, 8:17 PM   #10
JagoPlasma's Avatar
12,658, Level: 27
Points: 12,658, Level: 27 Points: 12,658, Level: 27 Points: 12,658, Level: 27
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 847, Got 387
they probably want to do it to save themselves a packet. money is tight everywhere and everyone wants to save a buck (look at the state of modern house builds)
its upto you, do you think it will stand the weather that we keep getting?
saying it will last 40 years is shocking. i have a brick built house that is 51yrs old, it looks as sturdy as the day it was built (well im not 51 but id imagine it does) and i hope it will stay like this for another 100yrs with minimal maintenance.
get what you can out of it
Old 06-09-2008, 9:35 PM   #11
4,613, Level: 16
Points: 4,613, Level: 16 Points: 4,613, Level: 16 Points: 4,613, Level: 16
Thanks: Gave 24, Got 108
I'm in a timber frame house with tropical storm Hannah passing by at present and all seems fine, though they do creak a little which takes some getting used to. Longevity wise we were told 30-40 years, but this doesn't mean the place will not be here in 30-40 years, just that the lumps on the exterior plywood shell will likely need work by then. Modern places have a tyvek wrap to improve sealing and life span.
Old 06-09-2008, 9:48 PM   #12
emporer's Avatar
12,296, Level: 26
Activity: 20.1%
Our house was built in the 50s and is rock solid, much more sturdier than the stuff built today, if we can then I think we would rather have something that would last although the max budget is 30k and out of that if we plan to build above the utility room then 12k would be spent on a through floor lift.
I suppose its just wait and see what the H&S officer comes up with when she does the feasiblity study.
Old 06-09-2008, 10:30 PM   #13
GasDad's Avatar
4,991, Level: 16
Err yes, because our building regs are finally catching up with the Scandanavians.
Old 10-09-2008, 10:22 AM   #14
Franco50's Avatar
4,236, Level: 15
Points: 4,236, Level: 15 Points: 4,236, Level: 15 Points: 4,236, Level: 15
Thanks: Gave 46, Got 40
Not sure if some posters here are missing the point - I am assuming when the OP says 'timber frame' he means that only the framework of the extension will be timber, in which case none of the timber will be exposed to the elements as some posters seem to be thinking. An outer skin of brickwork or blockwork is built around it. Think of the timber frame as being the bones of a skeleton and the brickwork is the flesh!
As some have already pointed out, an awful lot of new housing in the UK is built in this manner (here in Scotland I believe it is around 50% of all new housing) and most of the homes I have lived in have been this type of construction - two of them being selfbuilds. Their insulation level is far higher than traditional brick and block. Just Google "timber frame homes" to see the amount of firms producing this type of home.
Just one comment I'm puzzed about - the OP's builder stating a lifespan of 40 years for the extension? That seems ridiculous.
Old 10-09-2008, 11:48 AM   #15
IronGiant's Avatar
25,179, Level: 38
Points: 25,179, Level: 38 Points: 25,179, Level: 38 Points: 25,179, Level: 38
Activity: 33.7%
Activity: 33.7% Activity: 33.7% Activity: 33.7%
Thanks: Gave 2,336, Got 4,988
http://www.beenthere-donethat.org.uk...ml#cambridge25
Is 500 years a better estimate?
Old 10-09-2008, 12:28 PM   #16
4,003, Level: 14
Points: 4,003, Level: 14 Points: 4,003, Level: 14 Points: 4,003, Level: 14
Activity: 7.2%
Activity: 7.2% Activity: 7.2% Activity: 7.2%
Thanks: Gave 96, Got 37
I live in a timber frame house and no prob with insurance company.But i try to sell my house a couple of year ago and some buyer could not get mortgage due of the frame structure of the house.I t could be i very little problem if you want to sell the house.
Old 10-09-2008, 9:14 PM   #17
Phil57's Avatar
3,205, Level: 13
With so many houses in the UK built using timber frame I find it hard to believe that.
What mortgage lenders were they using?.........................backstreet lenders perhaps?
Old 10-09-2008, 9:24 PM   #18
16,091, Level: 30
I must have just been imagining it for all those years I was working in the mortgage industry then.
Old 11-09-2008, 9:55 AM   #19
emporer's Avatar
12,296, Level: 26
Activity: 20.1%
Say we have the timber frame extension, either as the single storey at the back or as the extension above the utility room, would this adversly affect any potential buyers if we ever sell the house? the rest of the house is brick and proper solid too.
Old 11-09-2008, 11:41 AM   #20
Phil57's Avatar
3,205, Level: 13
We are talking timber frame, not timber buildings.
Old 11-09-2008, 7:26 PM   #21
16,091, Level: 30
Type 'non standard construction' into google you'll see numerous sites all listing timber frame property as a difficult to mortgage property type.
I'm trying to warn someone based on years of experience dealing with valuations for all types of property including timber frame, and you call my warning 'nonsense' without any actual knowledge of the subject. Clearly marshall_nathan doesn't think I'm talking nonsense and I can assure you it's got nothing to do with 'backstreet lenders'.
Every mortgage company has different criteria but you need to tread carefully with anything classed as non-standard, and timber framed is most definitely classed as non-standard constructon.
Old 12-09-2008, 10:19 AM   #22
emporer's Avatar
12,296, Level: 26
Activity: 20.1%
I can understsand the point you make, lenders may well be wary of timber framed structures as a whole but in my situation the house is normal brick and only the extension would be timber framed, is this liable to make selling more difficult with regards to lenders?
Old 12-09-2008, 11:26 AM   #23
mattrixdesign2's Avatar
19,418, Level: 33
Points: 19,418, Level: 33 Points: 19,418, Level: 33 Points: 19,418, Level: 33
Activity: 6.8%
Activity: 6.8% Activity: 6.8% Activity: 6.8%
Thanks: Gave 521, Got 285
I know nothing about building(s), but a 40 year life span is a concern!!!
Old 12-09-2008, 3:03 PM   #24
4,003, Level: 14
Activity: 7.2%
.I m not getting any money telling lies.Is clearly state to me from my local estate agency W.B.P who i lost two buyer becouse the mortgage lender do not trust on this tipe of costruction,i was surprise myself but after a reserch i can say is truth.So if i have to buy or suggest what tipe of costruction buy or build i m go for a brick one.
