Originally Posted by danmc_82 How long does it take you to sharpen your chain? Do you just use a file? |
I usually take anything between 30 and 60 minutes, not hurrying at all, but if it is just a touch-up you can do it quicker.
You have to make sure that you get the correct size file, and that it has a comfortable handle, no good working with a bare file, and have the tang digging into your palm. Personally, I don't like holding the bar with one hand, and sharpening with the other, but if you are out in the woods you really have no choice.
Getting a guide is a good idea, and makes it more likely that you get a consistent angle on the teeth, but if you use a vice to hold the bar, this helps a lot anyway.
The local hardware store will sharpen the chain for around 5 Euros, but they sometimes take off too much, which means that they can sell you a new chain all the sooner.
JohntheExpat is quite correct. A dull chain is dangerous, and puts a strain on your motor, and your back. A sharp chain is safer, and better all round.
Hope that you find this helpful.
