Go Back   AVForums.com > Lifestyle Topics > General Chat
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray Review
Scrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Legal Advice wanted; Re leaky roof and builders Dwayne Dibley General Chat 6 10-06-2008 3:43 PM
up on the roof pixelpixel Past Entries 3 18-09-2006 10:20 AM
projector cabling from the roof! some sort of plate to hide the hole?? mh8701 Projectors 7 12-04-2006 7:39 PM
projector cabling from the roof! some sort of plate to hide the hole?? mh8701 Interconnects, Speaker Cables and Switches 5 12-04-2006 3:39 PM
Old 04-09-2008, 11:32 AM   #1 (permalink)
dUnKle's Avatar
Thanks: Gave 190, Got 147
How do I sort out my leaky Garage roof ?
We have an attached garage on the house which has a flat roof
Noticed few weeks back what looked like a damp patch and upon investigation it appeared there was a small leak.
Today the rain being as heavy as it is the leak is more noticable, its more of a drip than anything but certainly damp on the ceiling is noticable more than ever
The top of the garage looks like this
How do I go about repairing the roof of the garage ?
Noticed the bloke across from us a few weeks ago with what looked like a big roll of tar and grit on a sheet (image there is a technical term) laying this on top of his
I found http://www.diydoctor.org.uk/projects/repairflatroof.htm but not really sure what it is I need to buy
dUnKle is offline   Reply With Quote
Old 04-09-2008, 11:48 AM   #2 (permalink)
Thanks: Gave 95, Got 42
Re: How do I sort out my leaky Garage roof ?
You'll probably have to lay down new roofing felt which is available in most builders merchants.
This may help!!
zmoosa1 is online now   Reply With Quote
Old 04-09-2008, 11:54 AM   #3 (permalink)
dUnKle's Avatar
This may help!!
Good link - thanks
Anyone able to point me to directly what I need to go and buy (we have a Wickes nearby) and also maybe a site with actual photo illustrations ?
Old 04-09-2008, 12:01 PM   #4 (permalink)
Thanks: Gave 54, Got 126
Originally Posted by dUnKle View Post
Good link - thanks
It tells you what you need to buy in the materials section at the bottom of the page in the link provided
LG 50PQ3000 Plasma, Yammy A595 Amp,B&W CC3 centre Kef Coda 7 fronts
Mission 73 surrounds, Pioneer DV400 DVD Player (multi-region)
Crystal Xbox (modded with X3 + 250gig HDD)
Virgin Cable & Broadband
Kebabhead is offline   Reply With Quote
Old 04-09-2008, 12:06 PM   #5 (permalink)
Kieron's Avatar
Thanks: Gave 1,671, Got 1,105
Can you see where the water is coming in? You could try Flexacryl - you paint it on and it turns to rubber.
I used it for a few winters, alas this year we had to have a whole new flat roof put up.
The new roof has an incline on it now so the water runs down to a new drain pipe system.
Kieron is offline   Reply With Quote
Old 04-09-2008, 12:10 PM   #6 (permalink)
dUnKle's Avatar
Cheers all - feeling bit more positive
Upon closer inspection it appears to be a concrete roof with a very vin layer of what I think is called bichamen (sp?) but as can be seen in pic this is wearing away in places which happen to coincide with the damp patch
Think may get the Flexacryl and do emergency repairs on the next dry hour we get and then refelt next time we have better run of sun
Old 04-09-2008, 12:12 PM   #7 (permalink)
dUnKle's Avatar
Cheers - missed that
As said it appears the roof is concrete - does this make a difference ?
Old 04-09-2008, 12:16 PM   #8 (permalink)
Looking at the contours at the edge of the roof it may be best to use flexacryll only (rather than roof felt), as there seems to be a gully for drainage on the edge. Might be worth while applying a couple of coats initially and "topping-up" every couple of years!
Old 04-09-2008, 12:17 PM   #9 (permalink)
Thanks: Gave 51, Got 480
Wickes have a selection of sealants, both emergency and permanent:
http://www.wickes.co.uk/Weatherproof...t/wproofrepliq
GaryB is offline   Reply With Quote
Old 04-09-2008, 12:35 PM   #10 (permalink)
dUnKle's Avatar
Cheers for that
Old 04-09-2008, 3:35 PM   #11 (permalink)
PJTX100's Avatar
Thanks: Gave 256, Got 280
Get a tin of sealant and slap it on.
Your biggest challenge may be finding a window of opportunity between the rain.
A man's life in these parts often depends on a mere scrap of information.
PJTX100 is online now   Reply With Quote
Old 04-09-2008, 3:50 PM   #12 (permalink)
Kieron's Avatar
The only issue I found is finding exactly where the water was getting in. Yes there will be a wet patch, but the actual crack in the felt could be meters away.
Trial and error I'm afraid - I don't envy you having done it every year for the past 4/5 years....
Old 04-09-2008, 4:17 PM   #13 (permalink)
IronGiant's Avatar
Thanks: Gave 583, Got 1,559
Not having much luck with that house are you dUnKle?
For a temporary repair a can of car underseal works a treat, but only if you are planning to get it re-roofed as getting it off would be a nightmare. If you pop into Wickes they have a good leaflet describing replacing roofing felt. I think they have two systems, one bitumen based, the other a bit more DIY user friendly, I bit the bullet and had mine done professionally in the end.
Dave
We all stand on the shoulders of giants...
My personal opinion is not necessarily AVF policy.
IronGiant is offline   Reply With Quote
dUnKle (04-09-2008)
Old 04-09-2008, 6:25 PM   #14 (permalink)
dUnKle's Avatar
Dave
To be fair problems are not reall as bad as they may seem - just me striving to want everything perfect
Got bit of time off this month so going to get a couple of tins of the temp stuff to put up there and then wait til spring next year and look at doing a more perm job
Been told by Wickes that it being concrete increases my options
IronGiant (04-09-2008)
Old 04-09-2008, 7:23 PM   #15 (permalink)
PJTX100's Avatar
When we moved into our house, you could see the stars through the garage roof.
If that makes you feel any better.
garage, leaky, roof, sort
