Vinyl Players
Old 03-09-2008, 8:59 PM   #1
1,197, Level: 7
Points: 1,197, Level: 7 Points: 1,197, Level: 7 Points: 1,197, Level: 7
Thanks: Gave 31, Got 4
Vinyl Players
Hi Guys
I'm not entirely sure where to post this, so mods move if necessary.
So anywho, I've been floating around recently with the idea of getting a vinyl player, record player, not entirely sure of the terminology. I'm unfortunately not a child who has had the joy of growing up with good music, never mind.
I don't really know much about them though, I do however absolutely love the idea of being able to listen to Bob Dylan, Pink Floyd, Sonic Youth etc... all on vinyl.
So guys, what should I be looking at. Is there such thing as an optical output on these devices of mystery? Otherwise, sound output, suggestions ?
Thanks very much.
Old 03-09-2008, 9:04 PM   #2
Conspicuous Member
IAN P's Avatar
18,180, Level: 32
Points: 18,180, Level: 32 Points: 18,180, Level: 32 Points: 18,180, Level: 32
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 125, Got 1,022
Re: Vinyl Players
If you look HERE it may give you a rough idea what you can get.
Also a usb option if you want to save your vinyl to the pc.
Digital co-ax instead of optical,i think.
gears guy (03-09-2008)
Old 03-09-2008, 9:06 PM   #3
1,197, Level: 7
Re: Vinyl Players
Thanks !
I do definitely not want to save the tracks though, I want to move away from the computer as much as possible !!!
Old 03-09-2008, 9:15 PM   #4
DJACID's Avatar
12,575, Level: 26
Points: 12,575, Level: 26 Points: 12,575, Level: 26 Points: 12,575, Level: 26
Thanks: Gave 3, Got 151
Cool Re: Vinyl Players
go for one with usb,
as you can save all ur tracks to mp3...
Old 03-09-2008, 9:31 PM   #5
Thanks: Gave 4, Got 1
Re: Vinyl Players
See my above comment
@Ian P
http://www.a1-sound.co.uk/product/pr...fda017e8b6b30f
I really like that one man !
Old 03-09-2008, 9:32 PM   #6
Conspicuous Member
overkill's Avatar
10,886, Level: 25
Points: 10,886, Level: 25 Points: 10,886, Level: 25 Points: 10,886, Level: 25
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 269, Got 681
Re: Vinyl Players
Why would you want to do that? No offence but taking a high quality signal and turning it into Mp3's is like brewing great beer and then freezing the life out of it and removing all the flavour!
Or something like that........
For someone starting out with vinyl go for one of the projects or one of the lower end Rega's.
If you want to move into the murky World of 2nd hand TT's you can get a quality TT for a fraction of the price of buying new.
Old 03-09-2008, 9:35 PM   #7
Re: Vinyl Players
Precisely why I want to get away from my computer... plus, there's just something about just playing Dark Side of the Moon on my Uncle's vinyl player at 4am... You don't get that with a computer.
Question, just been reading and sites keep mentioned cartridges, can someone explain that please ?
Old 03-09-2008, 9:44 PM   #8
Conspicuous Member
IAN P's Avatar
18,180, Level: 32
Activity: 6.1%
Re: Vinyl Players
The cartridge is the place where the needle sits,some of these cartridges sell for thousands,crazy i know.
Here's a guide
Old 03-09-2008, 9:55 PM   #9
Re: Vinyl Players
*goes and finds hat* >>> *tips hat*
Old 03-09-2008, 9:59 PM   #10
Conspicuous Member
overkill's Avatar
10,886, Level: 25
Activity: 4.2%
Re: Vinyl Players
The Vinyl front end consists of three (well, four) parts.
The deck
The Tonearm
The Cartridge
We'll deal with four in a minute.
The deck contains the motor unit which drives the turntable itself. With cheaper decks the speed control is either flipping the drive belt over a two tier spindle, or some like the Projects have a built in 33/45 control. The more expensive decks have external power supplies that usually also control the speed. The decks also come in two flavours, belt or direct drive. The latter is the norm for DJ decks and is rarely seen on 'domestic' TT's. That's yer deck.
The Tonearm is a counterbalanced tube of metal (or more exotic things occasionally) which holds the cartridge in the groove. The arm has to be good at two things. One, keeping the cartridge firmly in the groove, two removing unwanted energy. The better the arm, the better the sound. The best budget arm in the universe is the Rega RB300.
The Cartridge contains the magnets that vibrate when the stylus picks up the signals off the groove. They send a tiny electrical signal to through the arm to the next bit. Two things here. If the cartridge isn't aligned correctly the stylus cannot read the groove correctly and may even damage the record and itself. The other, with cheaper cartridges the styluses are pretty big and as such cannot 'dig out' the massive amount of info in the groove. There are two flavours, Moving Magnet and Moving Coil. The MM's tend to dominate at the lower price point.
Right, that's a very simple run down of each bit.
Now to number four. This is the phono stage. This little device has to take that low level signal and convert it into a higher output for the Amp. I won't go into the various other tasks it has to do, but suffice it to say, from bitter experience, a crap phono stage can sabotage even the best TT.
Now here's the good news. There are plenty of good quality, reasonably priced TT's with decent arms and that come with a good enough quality cartridge. Rega, Project et al fit the bill.
At the same time their are now a few decent, cheap Phono stages, some of which put to shame the phono input on some pretty expensive older amps.
Again Project shine here, as do Creek.
Hope that helps.
Old 03-09-2008, 10:00 PM   #11
Conspicuous Member
overkill's Avatar
10,886, Level: 25
Activity: 4.2%
Re: Vinyl Players
Ian P, you saved me the job! I was going to link to that article!
Old 03-09-2008, 10:02 PM   #12
Conspicuous Member
IAN P's Avatar
18,180, Level: 32
Activity: 6.1%
Re: Vinyl Players
@Ian P
It's a beaut alright,hope it comes with a plastic cover for dust protection
Old 03-09-2008, 10:03 PM   #13
Conspicuous Member
IAN P's Avatar
18,180, Level: 32
Activity: 6.1%
Re: Vinyl Players
Tis' a very good read
Old 03-09-2008, 10:37 PM   #14
Illustrious Member
40,945, Level: 49
Points: 40,945, Level: 49 Points: 40,945, Level: 49 Points: 40,945, Level: 49
Activity: 31.8%
Activity: 31.8% Activity: 31.8% Activity: 31.8%
Thanks: Gave 277, Got 1,645
Re: Vinyl Players
I assume you have already got a amplifier and speakers of some kind? It doesn't have to be a Hi Fi one as some AV amps also have phono inputs (with a a phono stage built in). It is a analogue connection not a digital one.
I have had Technics decks for many years. I boguht a 30 years old deck for just £40 of ebay in mint condition. Along with a nice cartridge it sounds beautiful. The technology inside it has got popular with DJ's but was/is used for Hi Fi originally.
If you want to spend around £100 then a Project deck is a quick and good solution.
Old 03-09-2008, 10:50 PM   #15
Illustrious Member
la gran siete's Avatar
Location: Deep in the bowels of sussex where the angloargies live
12,805, Level: 27
Points: 12,805, Level: 27 Points: 12,805, Level: 27 Points: 12,805, Level: 27
Thanks: Gave 1,449, Got 854
Re: Vinyl Players
Originally Posted by Someguy View Post
Hi Guys
Thanks very much.
some good info on vinyl in here
http://www.vinylengine.com/phpBB2/in...bf99fb363f7890
decent TTs start with this one
http://www.techradar.com/products/au...-102019/review
Old 04-09-2008, 8:02 AM   #16
Conspicuous Member
Ed Selley's Avatar
9,841, Level: 23
Points: 9,841, Level: 23 Points: 9,841, Level: 23 Points: 9,841, Level: 23
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 44, Got 999
Re: Vinyl Players
Well in a shameless an smug threadjack, I've got one of these turning up this evening;
I've got an SME309 on order, although that isn't due for a while. Cartridge umming and ahhing is currently underway.
Old 04-09-2008, 9:15 AM   #17
15,613, Level: 30
Points: 15,613, Level: 30 Points: 15,613, Level: 30 Points: 15,613, Level: 30
Thanks: Gave 393, Got 344
Re: Vinyl Players
^^^^^ - is that a cool piece of kit, or what.
But if you do want to go down the route of converting your vinyl to MP3 to listen to on your MP3 player on the move, then I recently saw this demo'd on QVC:
http://www.qvcuk.com/ukqic/qvcapp.as...l,html&cmtags=
Old 04-09-2008, 10:26 AM   #18
Conspicuous Member
overkill's Avatar
10,886, Level: 25
Activity: 4.2%
Re: Vinyl Players
That looks suspiciously like a Gyrodeck, Ed? I prefer the bronzed version myself. A m8 I used to work with in the trade bought that colour Gyro through the outlet we worked in.
He had an SME IV on his that was lifted from his old deck.
Look great, sound great too.
If the OP is looking for vinyl releases, a good place to go is Diversevinyl.com. They are normally up to date and there's also normally a pretty hefty list reflecting the current resurgence in interest.
I can remember the mid 90's when virtually nothing was being issued on LP. Hell it was nothing!
On that note I need to go to the music forum........
Old 04-09-2008, 11:09 AM   #19
Conspicuous Member
Ed Selley's Avatar
9,841, Level: 23
Activity: 1.9%
Re: Vinyl Players
Look great, sound great too. .
Yep- a full plinth Gyro with the Gert Pedersen suspension mods (not visible in that pic). I'm a happy chappy and the SME will be a good partner.
