Originally Posted by dUnKle Looking to get my hall, stairs and landing painted today and tommorow before the new floor gets put down (fingers crossed) in next few days
We are painting it all - Walls magnolia and then glossing the skirting etc
However we also have the banister and balistrade on the stairs and doors to a couple of cupboards. These are currently glossed. Now have sanded down the gloss as best I can (although paint is still there, just not as shiny) and got rid of all the previous drips that where there
(1) Can I just paint over gloss ?
(2) Whats a good white paint that gives a nice clean fresh smooth look, but without being glossy and can this be painted on top of gloss ?
(3) The magnolia for the walls is (obviously) very stark - to me it looks like its not even been bothered with but the other half likes it - anyone able to recommend a suitable alternative ?
Im sure more questions will follow |
1) As long as the surface has been keyed well - ie roughened up with a good sanding - then yes, you can paint over gloss.
2) If you don't want gloss, but still want a shine, you should probably go for a silk emulsion - these give a good sheen. Be warned, it is unusual to paint wooden surfaces with emulsion, and because these are usually subject to heavy traffic (dirty hand-prints, shoe scuffs, etc), gloss is usually the best option. (Gloss can be wiped clean, whereas silk emulsion, though often sold as "wipe-clean" more often than not will need regular coats to keep it white - it's okay on walls, not so much on bannisters and the like).
3) Perhaps you could put up a dado rail (usually at a height of 30-36") or picture rail (usually at a height of 7-8') to break up your room - works well if you have high ceilings. If using a dado, you could either wallpaper or use a contrasting (darker) colour on the lower section of wall, and magnolia the upper half.
