L-Shaped Sofa
Old 08-07-2008, 6:15 PM   #1
Conspicuous Member
16,164, Level: 30
Points: 16,164, Level: 30 Points: 16,164, Level: 30 Points: 16,164, Level: 30
Activity: 10.6%
Activity: 10.6% Activity: 10.6% Activity: 10.6%
Thanks: Gave 1,239, Got 922
L-Shaped Sofa
Anybody know where you can buy quality l-shaped, corner unit sofas from?
I've tried all the usual culprits.
Dwell
Habitat
John Lewis
All the usual furniture chains, DFS, Home Furnishings etc etc
They are either poor quality or just don't feel comfortable etc.
I'm after something made a to a really high quality, contemporary but not ultra modern, and importantly comfy.
Price not really an issue.
Old 08-07-2008, 7:36 PM   #2
3,222, Level: 13
Points: 3,222, Level: 13 Points: 3,222, Level: 13 Points: 3,222, Level: 13
Thanks: Gave 36, Got 224
Re: L-Shaped Sofa
you could try http://www.natuzzi.co.uk/
john.
SimonH (08-07-2008)
Old 08-07-2008, 7:39 PM   #3
3,222, Level: 13
Re: L-Shaped Sofa
or http://www.contemporary-furniture-ca...ner_sofas.html
john
SimonH (08-07-2008)
Old 08-07-2008, 8:01 PM   #4
shodan's Avatar
8,220, Level: 21
Points: 8,220, Level: 21 Points: 8,220, Level: 21 Points: 8,220, Level: 21
Activity: 8.0%
Activity: 8.0% Activity: 8.0% Activity: 8.0%
Thanks: Gave 206, Got 578
Re: L-Shaped Sofa
Got my rather large one (Ooerr missus!) from www.nabru.co.uk
SimonH (08-07-2008)
Old 08-07-2008, 8:37 PM   #5
Conspicuous Member
16,164, Level: 30
Activity: 10.6%
Re: L-Shaped Sofa
Thanks folks, some really good options there, excellent.
Old 08-07-2008, 10:35 PM   #6
lord-dudester's Avatar
4,270, Level: 15
Points: 4,270, Level: 15 Points: 4,270, Level: 15 Points: 4,270, Level: 15
Thanks: Gave 673, Got 172
Re: L-Shaped Sofa
john lewis are always worth a try...
SimonH (10-07-2008)
Old 08-07-2008, 10:50 PM   #7
8,709, Level: 22
Points: 8,709, Level: 22 Points: 8,709, Level: 22 Points: 8,709, Level: 22
Thanks: Gave 368, Got 107
Re: L-Shaped Sofa
If price is not a issue:
http://www.ligne-roset.co.uk/?sec=products&pid=11
Highly recomended
SimonH (10-07-2008)
Old 09-07-2008, 7:05 PM   #8
2,737, Level: 12
Points: 2,737, Level: 12 Points: 2,737, Level: 12 Points: 2,737, Level: 12
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 62, Got 73
Re: L-Shaped Sofa
Try Bo Concept at http://www.boconcept.co.uk. I can vouch for the quality and service at the shops. The designs, well, that's up to you.
Dave
SimonH (10-07-2008)
Old 10-07-2008, 8:08 AM   #9
Conspicuous Member
16,164, Level: 30
Activity: 10.6%
Re: L-Shaped Sofa
Thanks again, never even heard of some of these stores before, plenty of choices many of them carrying exactly what I'm after.
PS tried JL was a bit underwhelmed, I think these "independents" are looking good however.
Old 10-07-2008, 8:17 AM   #10
DJT75's Avatar
9,202, Level: 22
Points: 9,202, Level: 22 Points: 9,202, Level: 22 Points: 9,202, Level: 22
Thanks: Gave 211, Got 504
Re: L-Shaped Sofa
Had the same problem, only one we liked we found in Cargo Homeshop just over a year ago. Doesn't appear to be on the website anymore but you must be able to still buy it as all the stores still have it on display. Not cheap but exactly what we wanted. They do it is loads of difference colours too.
http://www.cargohomeshop.com/home/default.aspx
Photo of my one on this thread:
Get your sofa's out for the lads!!!
SimonH (10-07-2008)
Old 10-07-2008, 4:52 PM   #11
3,222, Level: 13
Re: L-Shaped Sofa
Another one http://www.atomicinteriors.co.uk/amb...hp?category=18
john
Old 10-07-2008, 4:56 PM   #12
3,222, Level: 13
Re: L-Shaped Sofa
http://www.espacio.co.uk/cgi-bin/pro...rary_sofas.asp
And Another..
John.
