Need some advise on my lawn
Old 18-06-2008, 8:08 PM   #1
metalhead72's Avatar
10,631, Level: 24
Points: 10,631, Level: 24 Points: 10,631, Level: 24 Points: 10,631, Level: 24
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 137, Got 143
We've just recently moved house,a couple of weeks before we moved in the landlord put down new turf.. Unfortunately he did'nt maintain it and the result of this is a brown patchy lawn with some green tufts of green grass scattered around.
How can I restore it back to health.. I've cut the grass and applied lawn feed and water it every other day.. What else can I do ?
Old 18-06-2008, 8:17 PM   #2
Phil57's Avatar
3,207, Level: 13
Points: 3,207, Level: 13 Points: 3,207, Level: 13 Points: 3,207, Level: 13
Thanks: Gave 600, Got 310
Re: Need some advise on my lawn
At the very least, water it twice a day but not in direct sunlight.
I am not a gardening expert, but I have just last week laid a hundred square meters of turf on my garden.
Old 18-06-2008, 8:23 PM   #3
10,631, Level: 24
Activity: 2.0%
Thanks, I did read some where that over watering can do more damage then good ? As you say .. Im not green fingered so I'm really pi**ing in the wind here !!
Old 18-06-2008, 9:16 PM   #4
Illustrious Member
la gran siete's Avatar
Location: Deep in the bowels of sussex where the angloargies live
12,810, Level: 27
Points: 12,810, Level: 27 Points: 12,810, Level: 27 Points: 12,810, Level: 27
Thanks: Gave 1,449, Got 854
sounds like the turf has nearly died out . You'll have to be partient, water as suggested and wait till the autumn.Hopefully by then it'll have recovered.
Old 18-06-2008, 9:51 PM   #5
12,577, Level: 26
Points: 12,577, Level: 26 Points: 12,577, Level: 26 Points: 12,577, Level: 26
Activity: 4.9%
Activity: 4.9% Activity: 4.9% Activity: 4.9%
Thanks: Gave 205, Got 940
It's possible that there's not enough soil below the turf, e.g. it may be laid on concrete.
Assuming it isn't, water regularly as suggested and use a decent "lawn restorer" type treatment and maybe re-seed the worst areas.
Old 19-06-2008, 6:50 AM   #6
Adam Shaw's Avatar
2,836, Level: 12
Points: 2,836, Level: 12 Points: 2,836, Level: 12 Points: 2,836, Level: 12
Thanks: Gave 24, Got 101
I would go with LGS's advice, as he does this for a living.
my 2p worth is dont cut it too short, leave plenty of length where you can until its looks healthier, but I doubt you will have a nice green lawn until next summer
Old 19-06-2008, 8:51 AM   #7
Illustrious Member
12,810, Level: 27
yes if the soil is poor (ie little topsoil)you are not going to get a great lawn but it sounds like it has bee neglected.Newly laid turf must be watered right from the outset.In fact the soil should be damp when they are first laid othwerwise they shrink and you get gaps appearing between them.
I remember during the 1976 drought some turf was laid outside some council flats which went brown but it did eventually recover.
Old 19-06-2008, 1:34 PM   #8
Beobloke's Avatar
3,824, Level: 14
Points: 3,824, Level: 14 Points: 3,824, Level: 14 Points: 3,824, Level: 14
Thanks: Gave 4, Got 58
I can highly recommend Evergreen's Lawn Repair Kit which rejuvenated my completely knackered lawn very well. Needs to be applied in March, though!
http://www.lovethegarden.com/product...repairkit.html
Given the dead patches of grass appearing thanks to the builders we have in at the moment dumping stuff on the lawn, I guess I'll be using it again next year...
Old 19-06-2008, 1:49 PM   #9
danmc_82's Avatar
8,057, Level: 21
Points: 8,057, Level: 21 Points: 8,057, Level: 21 Points: 8,057, Level: 21
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 935, Got 373
My grass was crap when I moved in november. Ive cut it as often as I can so the light can get to the botom of the grass which helps stop the yellowing. Its getting really good at the mo. The rain last night did it some good.
Old 19-06-2008, 1:56 PM   #10
loz loz is offline
Conspicuous Member
30,195, Level: 42
Points: 30,195, Level: 42 Points: 30,195, Level: 42 Points: 30,195, Level: 42
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 281, Got 815
We have a groundsman. Doesn't everybody?
Well, when I say we have a groundsman, I mean we have this lot in to improve the condition of our lawn
http://www.lawnmaster.co.uk/
Not too expensive. Still in the middle of the course of treatment, so I can't vouch for the result yet. But we saw some of our neighbours using them and getting good results, so we are trying them too.
