27-05-2008, 2:06 PM
#1 (permalink)
| | Senior Member
Thanks: Gave 164, Got 64 | MS Access help please!
Hopefully someone can help with this seemingly simple question (I've Googled but can't get an answer).
How can I apply the same properties to multiple fields, in one go? For example I have 22 fields which all started off as text, but now I want to change them to number, with 1 decimal place displayed. I can't find any way to do it other than select each field, and adjust its properties, then the next field, and so on....
Thanks in anticipation...!
__________________ My equipment: Cordless telephone, remote control colour TV, home computer ("PC"), digital watch. |
27-05-2008, 2:13 PM
#2 (permalink)
| | Senior Member
Thanks: Gave 73, Got 384 | Re: MS Access help please!
Highlight all of the boxes that you want to change, right click, properties, All, box 2 is type and 3 is decimal points.
27-05-2008, 2:18 PM
#3 (permalink)
| | Senior Member
Thanks: Gave 164, Got 64 | Re: MS Access help please!
When I highlight all the fields (I am in main table, design view), and right click, properties, I don't get the properties of the fields, I get an option to change the properties of the table!
I am trying to re-design a database (which I previously constructed!) from the bottom up and am realising how thick I am - I have no chance of doing this right!
Aaaargh!
27-05-2008, 2:24 PM
#4 (permalink)
| | Senior Member
Apologies, I did not read properly, I thought you wanted to change them in a form.
If you are in table view you only need to change the drop down to change the type. Should only take a matter of seconds to change them all.
27-05-2008, 2:28 PM
#5 (permalink)
| | Senior Member
Yes, but I also want to change the number of decimal places (which seems to default to zero, annoyingly).
looks like I will have to change them individually. thanks for your time.
27-05-2008, 2:32 PM
#6 (permalink)
| | Senior Member
Or just change one, copy and paste that then change the field names (not going to be much quicker than changing them all individually though.
