Ok, i've been with my current dentist since i moved to the area in Nov 2004. When i registered, i had a full checkup and set of x-rays, and had a very small amount of work done, i think i had a filling replaced, and the usual scale and polish.
As directed by the dentist, i had checkups at 6 or 9 months, of which every time i went, i was given a clean bill of health.
Around 4 weeks ago, one of molars broke into 2 pieces. This tooth already had a white filling, and the tooth had broke around the white filling. I went to see my dentist, and the diagnosis was that the white filling had shrunk over time, the tooth had cracked and the gum had grown into the tooth, forcing it apart. I find this all a bit far reached to be believed, but the dentist assured me that it does happen.
Anyway, i made another appoinment to have the tooth and the remaining filling cleaned out, and to see what state the tooth is in. After a bit of drilling and poking, she decided that i needed root canal, but she would not be able to perform the work, as she didn't have the required equipment to remove the excess gum. I would be referred to a specialist to have the work carried out.
So far, not bad. About 3 days after this, i had a pain in another tooth, so bad that i couldn't sleep. First thing in the morning, at 9am, i'm queuing outside the dentist, after waiting 30 mins, i discover my dentist doesn't work Fridays
The recipentist managed to have another dentist in the area have a look at my tooth who quickly discovered i had an abcess under the tooth, and root canal was needed. The root canal could not be completed until the abcess had died, so i get some anti-biotics, and told to back to my original dentist and make an appointment for a weeks time for the root canal.
Turn up for the appointment, the dentist has a quick look, and refuses to do the root canal, instead suggesting that the specialist who will be doing the first tooth should also do this other tooth.
So i've had around 5 dentist appoinments, but i'm still no closer to getting either tooth fixed. I was referred to the specialist over 3 weeks ago, and i've heard nothing. I was originally told that i should have the work completed in 3 weeks, but i've spent the last 10 days chasing people up, just to get an appoinment.
I just can't get somebody to get the damned work done. And i'm not NHS, i'm private!! I thought they'd be snapping my hand off, for two root canals, Gingivoplasty (Gum Removal), and a crown!
I'm a bit ****** off that, during my checkups the problems weren't detected any earlier, otherwise what is the point in checkups and her near refusal to do the work. Any dentists want to comment?
Hold on, what am i saying, after reading what i've just wrote, i think i should change dentists!
Just received a call from the specialists, and they did not receive the referral letter until the 15th April
Three weeks after my dentist said they sent it, so somebody is telling porkies!
I'm so ****** off now.
