mobile answerphone message export
Old 10-03-2008, 2:54 PM   #1
4,854, Level: 16
Points: 4,854, Level: 16 Points: 4,854, Level: 16 Points: 4,854, Level: 16
Thanks: Gave 4, Got 1
Just been asked this by a colleague
Is there a way to take an answerphone message from a mobile to record onto a p.c
I.e accessing voicemail to make into a wav file
Cheers,
Old 10-03-2008, 3:01 PM   #2
Henry's Avatar
12,938, Level: 27
Points: 12,938, Level: 27 Points: 12,938, Level: 27 Points: 12,938, Level: 27
Activity: 0.9%
Activity: 0.9% Activity: 0.9% Activity: 0.9%
Thanks: Gave 37, Got 59
Re: mobile answerphone message export
Probably only by physically playing it out loud and recording it.
Old 10-03-2008, 3:02 PM   #3
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
might be possible with data cable and software to download a oicemail, I would ring tech support for the handset manufacturer. (you cold put the phone on speaker and use a mic connected to PC)
Or ring your voicemail from a phone attached to a switchboard with archive call monitoring (ie records all calls) ther eis a number you ring enter your mobile number and a PIN and get remote voicemail access do this via a switch board that records all external calls then pull it off the archive (will need IT tech or phone company to pull it off the server)
