Tax Back
Old 07-11-2007, 8:18 PM   #1
Chaos's Avatar
21,660, Level: 35
Points: 21,660, Level: 35 Points: 21,660, Level: 35 Points: 21,660, Level: 35
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 93, Got 196
Question Tax Back
If I buy things for work is there any way to claim back VAT? I can't find anything about it anywhere.
Old 07-11-2007, 8:27 PM   #2
Bluehorse
Posts: n/a
Re: Tax Back
Are you self employed, own your own business or do you work for a company?
If you work for someone, normally you claim back the full amount and they claim the Vat using the receipts you have to provide.
If you work for yourself you need to be Vat registered and complete a return every quarter in most cases. You tell them what Vat you paid and what you receved, pay them any excess if you paid less out in Vat than you charged. Otherwise they send you a refund.
You should be able to find loads at: www.hmrc.gov.uk
www.hmrc.gov.uk
Old 07-11-2007, 8:28 PM   #3
Chaos's Avatar
21,660, Level: 35
Activity: 2.3%
Re: Tax Back
I work for a company but I will be the one paying for the items.
Old 07-11-2007, 9:17 PM   #4
Moosh's Avatar
8,455, Level: 22
Points: 8,455, Level: 22 Points: 8,455, Level: 22 Points: 8,455, Level: 22
Thanks: Gave 823, Got 429
Re: Tax Back
As you work for a company then the first part of what Bluehorse says applies. You will claim the cost of the item back from the company and the company, if they are VAT registered, will claim the VAT back.
Moosh
Old 07-11-2007, 9:56 PM   #5
Chaos's Avatar
21,660, Level: 35
Activity: 2.3%
Re: Tax Back
Are you saying my work have to pay for this? There is no reason they should in my opinion.
Old 07-11-2007, 10:18 PM   #6
Illustrious Mumbler
Mr Incredible's Avatar
19,482, Level: 33
Points: 19,482, Level: 33 Points: 19,482, Level: 33 Points: 19,482, Level: 33
Activity: 11.0%
Activity: 11.0% Activity: 11.0% Activity: 11.0%
Thanks: Gave 1,656, Got 3,421
Re: Tax Back
Ah, I think I see what you mean. You're buying something for yourself which you use for work?
If so, and it can be proved that the item is a necessary part of your job but your company is not prepared to buy it for you, then I believe you can claim against your tax code (income not VAT), so you get tax relief on the amount you pay. You will need a letter from your employer stating this is the situation.
You can also get tax relief, I think, on membership fees to professional bodies in line with your work.
Is that what you meant?
Old 08-11-2007, 6:44 AM   #7
Chaos's Avatar
21,660, Level: 35
Activity: 2.3%
Re: Tax Back
Yeah this is exactly what I mean. Any idea if I can get a form from somewhere?
Old 08-11-2007, 9:41 AM   #8
Illustrious Mumbler
19,482, Level: 33
Activity: 11.0%
Re: Tax Back
I think you can only claim it back after the end of the taxc year when you complete a self assesment tax return. IIRC there is a section in the form for this type of "expenditure", but not sure if this relates only to self employed.
In any instance it is not the VAT you will be getting back. You will be looking for a tax allowance against your taxable income.
Check with your local tax office as they can best advise.
Old 08-11-2007, 12:43 PM   #9
15,816, Level: 30
Points: 15,816, Level: 30 Points: 15,816, Level: 30 Points: 15,816, Level: 30
Thanks: Gave 583, Got 289
Re: Tax Back
If it's related to health or safety the employer must pay for it and not pass the cost on the the employee.
Old 08-11-2007, 1:23 PM   #10
Illustrious Mumbler
19,482, Level: 33
Activity: 11.0%
Re: Tax Back
And if it's not for health and safety then anything you "need" for work is personal choice and probably not liable for relief.
Old 08-11-2007, 2:04 PM   #11
mason's Avatar
5,385, Level: 17
Points: 5,385, Level: 17 Points: 5,385, Level: 17 Points: 5,385, Level: 17
Thanks: Gave 62, Got 85
Re: Tax Back
yeah there is no way around the VAT- you cant claim it back but you can claim the purchase (if necassary for your job role) against your tax code.
phone up Inland Revenue and advise them what you are buying and they should (and i say should in capital letters!!!) sort this for you over the phone and sent you out a form that will enable you to claim this way.
Old 08-11-2007, 2:05 PM   #12
mason's Avatar
5,385, Level: 17
Re: Tax Back
bang on the money.
if its simply a 'it would make my job easier' items and not necessary then you wont be able to claim any kind of releif.
