How hard is the infocomm basic accreditation
Old 03-10-2007, 10:49 AM   #1
7,014, Level: 19
Points: 7,014, Level: 19 Points: 7,014, Level: 19 Points: 7,014, Level: 19
Thanks: Gave 106, Got 125
Am seriously thinking about doing it, but have only ever worked in educational AV which is exactly the most challenging..... what type of stuff will i need to know etc?.....
Old 03-10-2007, 11:44 AM   #2
7,014, Level: 19
Re: How hard is the infocomm basic accreditation
sorry that should be 'isnt exactly'
Old 03-10-2007, 10:24 PM   #3
lisa burrell
Posts: n/a
Entry requirements in the GCE ‘O’ Level examinations (or equivalent) are:
Subject ‘O’ Level Grade
1. English Language (EL1)
1-7
2. Mathematics (Elementary/Additional)
1-6
3. Any three other subjects (excluding CCA)
1-6
Candidates with hearing deficiency or severe vision deficiency including color appreciation deficiency should not apply for the course.
Candidates must have also met the requirements for aggregate computation.
The aggregate computation for selection is based on grades obtained for English, Mathematics, Science (with Physics or Chemistry or Biology component) or Design & Technology, and two other subjects (excluding CCA).
All sounds a doddle to me
Lis@
Old 03-10-2007, 11:58 PM   #4
7,014, Level: 19
I have 9 gcse's
A's
Photography
B's
Maths, Double science, history, eng lang and eng lit, (cant remember the rest)
C's
French and spanish
I also have a'levels, a HND and a degree (all creative subjects)
I dont really know how all the o levels compare to gcse's
I dont have any sight problems really (slight long sightedness) and as far as i know pretty good hearing
Have also worked as an AV, Photography and IT technician
do you reckon that'd be ok?
