10 reasons why your fish die!
Old 07-09-2007, 3:03 PM   #1
Synchro's Avatar
12,703, Level: 27
Points: 12,703, Level: 27 Points: 12,703, Level: 27 Points: 12,703, Level: 27
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 143, Got 158
1: Other Fish
2: Disease, Bacteria and Parasites
3: Stress
4: Overcrowding
5: Overfeeding
6: Improper Mechanical Filtration
7: Improper Chemical Filtration
8: Improper Temperature
9: Are you really reading this list?
10: How You Treat The Fish To Begin With
Old 07-09-2007, 3:09 PM   #2
Steven's Avatar
61,781, Level: 60
Points: 61,781, Level: 60 Points: 61,781, Level: 60 Points: 61,781, Level: 60
Activity: 33.1%
Activity: 33.1% Activity: 33.1% Activity: 33.1%
Thanks: Gave 2,014, Got 4,412
Re: 10 reasons why your fish die!
Because they are kept in a tank against their will by self-assuming humans?
Old 07-09-2007, 3:13 PM   #3
Marky1973's Avatar
7,455, Level: 20
Points: 7,455, Level: 20 Points: 7,455, Level: 20 Points: 7,455, Level: 20
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 360, Got 212
they get battered?
Old 07-09-2007, 3:16 PM   #4
Preeminent Member
Razor's Avatar
88,790, Level: 72
Points: 88,790, Level: 72 Points: 88,790, Level: 72 Points: 88,790, Level: 72
Activity: 47.6%
Activity: 47.6% Activity: 47.6% Activity: 47.6%
Thanks: Gave 2,109, Got 3,669
The chickens ate them...
Old 07-09-2007, 3:17 PM   #5
4,916, Level: 16
Points: 4,916, Level: 16 Points: 4,916, Level: 16 Points: 4,916, Level: 16
Thanks: Gave 91, Got 170
because they are trying to find nemo?
Old 07-09-2007, 7:24 PM   #6
2,531, Level: 11
Points: 2,531, Level: 11 Points: 2,531, Level: 11 Points: 2,531, Level: 11
Thanks: Gave 90, Got 163
They got shot in a barrel.
Old 07-09-2007, 7:38 PM   #7
Keyman
Posts: n/a
I still have to come across one which doesn't.
Old 07-09-2007, 9:37 PM   #8
bobsplace's Avatar
7,446, Level: 20
Points: 7,446, Level: 20 Points: 7,446, Level: 20 Points: 7,446, Level: 20
Thanks: Gave 53, Got 47
Seriously.we've lost 7 goldfish in three weeks!!clean the tank regular etc plus only 4 fish at any one time in a decent sized filtrated tank.
Any ideas
Old 08-09-2007, 12:02 AM   #9
Alan_W's Avatar
5,505, Level: 17
Points: 5,505, Level: 17 Points: 5,505, Level: 17 Points: 5,505, Level: 17
Thanks: Gave 109, Got 179
If you loved them, you would set them free back into the wild
Old 08-09-2007, 1:04 AM   #10
CDR CDR is offline
6,112, Level: 18
Points: 6,112, Level: 18 Points: 6,112, Level: 18 Points: 6,112, Level: 18
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 245, Got 319
11. Next door neighbours cat scoops it up out of the pond.
Old 08-09-2007, 2:35 AM   #11
partyweb's Avatar
11,725, Level: 25
Points: 11,725, Level: 25 Points: 11,725, Level: 25 Points: 11,725, Level: 25
Activity: 0.8%
Thanks: Gave 1,337, Got 549
Any ideas
I think these may be your main problems:
Originally Posted by Synchrouk View Post
3: Stress
4: Overcrowding
3 & 4: These two go hand in hand. What size & shape is the tank? If you''ve got one of these pretty Biorbs or a round standard bowl then you a severely restricted to the amount of fish as the oxygen in the tank is determined by the top surface area of the water and those round types have a far smaller area than normal. Adding an air pump or powerhead can help increase the oxygen and therefore the no of fish.
6 & 7: These two also go hand in hand. As water straight from the tap is lethal to fish (full of chlorine). Either treat it or leave it for a week. Your next problem is it can take up to 6 weeks to 'break-in' tank water. At first the tank is full of ammonia which is lethal to fish. This eases off but is replaced by nitrite which is lethal to fish. This gradually eases off but is funally replaced by nitrate which is only slightly lethal to fish. So it's a delicate balance to try and achieve with the water and not something to keep throwing away regularily. Also bacteriour in the tank is responsible for breaking down these harmful chemicles and these get lost with regular cleaning. Best method is to clean the tank with it's own water and then do a partial (say 10-20%) water change weekly.
8: Finally rapid temperature change is a great way to stress and therefor kill your fish. Have you got the tank near a window or in sunlight? As even just an increase in 1 deg from early morning sunshine can upset them.
Hope that helps.
bobsplace (08-09-2007)
Old 08-09-2007, 5:50 AM   #12
Eminent Member
kingfats's Avatar
106,213, Level: 79
Points: 106,213, Level: 79 Points: 106,213, Level: 79 Points: 106,213, Level: 79
Thanks: Gave 1,193, Got 7,647
Someone's been watching too much Free willy!
Old 08-09-2007, 6:40 AM   #13
johnny70's Avatar
4,263, Level: 15
Points: 4,263, Level: 15 Points: 4,263, Level: 15 Points: 4,263, Level: 15
Thanks: Gave 130, Got 71
I'm sure all the tank breed fish will be really happy about going to the wild
In some cases you know that certain species are near extinction and they have been brought back from the brink by breeder's willing to spend time and money to make sure we don't lose another species from the planet
for example the zebra pleco L046 has been over fished and also the brazilian government have decided to build a huge dam somewhere near there natural habitat, virtually wiping them out, and at £100 a fish it takes a lot to get them breeding.
Old 08-09-2007, 7:24 AM   #14
shodan's Avatar
8,221, Level: 21
Points: 8,221, Level: 21 Points: 8,221, Level: 21 Points: 8,221, Level: 21
Activity: 7.1%
Activity: 7.1% Activity: 7.1% Activity: 7.1%
Thanks: Gave 206, Got 578
What the hell have fish got to be stressed about????? I could teach them about stress!!! But then I'd have to teach them about it again 7 minutes later....
Old 08-09-2007, 7:31 AM   #15
2,453, Level: 11
Points: 2,453, Level: 11 Points: 2,453, Level: 11 Points: 2,453, Level: 11
Thanks: Gave 127, Got 236
I refer the honourable gentleman to these wise words on extinction.
Old 08-09-2007, 12:35 PM   #16
johnny70's Avatar
4,263, Level: 15
Not sure I would use the therm 'wise words' with anything written by JC.
I for one do care, some other do, plenty don't, most people seem happy to spend £10000's on av/car/insert whatever. me i'll spend mine trying(and failing) to save what little bit of the plants inhabitents I can.
JOHNNY
Old 08-09-2007, 1:42 PM   #17
5,894, Level: 18
Points: 5,894, Level: 18 Points: 5,894, Level: 18 Points: 5,894, Level: 18
Activity: 4.2%
Thanks: Gave 214, Got 203
You can easily make a tank uninhabitable and useless by cleaning it. It's the chemicals that stay in minor surface scratches. Aquarium people can better advise.
