Hi New guy here after a bit of advice, Thank you in advance for your patience.
I have recently moved into a bungalow which has loads of low voltage spotlights in the ceilings.
The existing spotlights are either grotty or have been badly painted over and I am going to replace them.
Also I am getting the loft insulated on a cheap energy saving scheme and want the insulation to be effective and for it to go over the lights.
I am looking at getting the Fire rated Downlight Fixed MR16 12v from Toolstation
Toolstation > Lighting > Low Voltage Fire Rated Downlights > Linolite Sylvania Fire Rated Downlight Fixed MR16 12v
(as the holes already exist I am limited in my choice).
Now I think that will be OK as far as it goes but,
and here are the queries:
as they are "fire rated" do I need to get the fire vapour and thermal seal loft caps for each one?
Fire Vapour & Thermal Seal Loft Cap
Also, some of these lights are in the bathroom. How would this affect my activities?
I would prefer proper lights but the ceiling would need plastering and the wife doesn't want the associated mess.
Thanking you in anticipation.
