Little Puzzle
Old 12-06-2007, 7:13 AM   #1
mjn mjn is offline
18,257, Level: 32
Points: 18,257, Level: 32 Points: 18,257, Level: 32 Points: 18,257, Level: 32
Activity: 4.5%
Activity: 4.5% Activity: 4.5% Activity: 4.5%
Thanks: Gave 217, Got 609
Little Puzzle
Had a job interview yesterday, and had to do an IQ test. However one question stumped me:
What is the missing number?
3, 9, 27, ?, 243
I spent a fair bit of time on this, but couldn't think of the answer.
Anybody
Old 12-06-2007, 7:26 AM   #2
kraiklyn's Avatar
4,097, Level: 15
Points: 4,097, Level: 15 Points: 4,097, Level: 15 Points: 4,097, Level: 15
Thanks: Gave 141, Got 41
Re: Little Puzzle
81 seems to fit the pattern.
3, 9, 27, 81, 243
3x3 = 9
3x9 = 27
3x27 = 81
3x81 = 243.
Old 12-06-2007, 7:27 AM   #3
Mep Mep is offline
Conspicuous Member
Mep's Avatar
14,376, Level: 28
Points: 14,376, Level: 28 Points: 14,376, Level: 28 Points: 14,376, Level: 28
Thanks: Gave 442, Got 465
Re: Little Puzzle
Indeed!....not too tricky for a man of your calibre mjn!
Old 12-06-2007, 7:31 AM   #4
kraiklyn's Avatar
4,097, Level: 15
Re: Little Puzzle
It's probably one of those situations where you either see the pattern or don't. In an interview situation it probably throws you out a bit.
Old 12-06-2007, 8:07 AM   #5
mjn mjn is offline
18,257, Level: 32
Activity: 4.5%
Re: Little Puzzle
i got all the rest easily, but this one just threw me. I knew 3 had something to do with it, honestly.
Done a few of these tests before, and my scores are nearly always the same.
Old 12-06-2007, 1:40 PM   #6
Conspicuous Member
37,398, Level: 47
Points: 37,398, Level: 47 Points: 37,398, Level: 47 Points: 37,398, Level: 47
Activity: 25.4%
Activity: 25.4% Activity: 25.4% Activity: 25.4%
Thanks: Gave 4,654, Got 1,521
Re: Little Puzzle
Hi MJN,
Sorry you didn't get this one, but it probably should have been reasonably obvious. But, nonetheless, did you get the job, and what job have you been applying for?
Pooch
Old 12-06-2007, 1:43 PM   #7
Steven's Avatar
61,706, Level: 60
Points: 61,706, Level: 60 Points: 61,706, Level: 60 Points: 61,706, Level: 60
Activity: 37.9%
Activity: 37.9% Activity: 37.9% Activity: 37.9%
Thanks: Gave 2,014, Got 4,411
Re: Little Puzzle
Well if this happens to me in a couple of years, I hope they stick at this level. All that quadratics rubbish etc left my head ages ago
Old 12-06-2007, 2:00 PM   #8
jason g's Avatar
47,824, Level: 53
Points: 47,824, Level: 53 Points: 47,824, Level: 53 Points: 47,824, Level: 53
Activity: 31.1%
Activity: 31.1% Activity: 31.1% Activity: 31.1%
Thanks: Gave 3,611, Got 1,636
Cool Re: Little Puzzle
i got this easy enough but u do get some with are really hard to work out.
Old 12-06-2007, 2:03 PM   #9
jason g's Avatar
47,824, Level: 53
Activity: 31.1%
look at this one.
http://www.brainbashers.com/showpuzzles.asp?puzzle=ZPQT
Old 12-06-2007, 2:28 PM   #10
mjn mjn is offline
18,257, Level: 32
Activity: 4.5%
Re: Little Puzzle
There were plenty more, that was question 2 out of about 30, but that was the only one i could not work out.
There was the usual array of maths, logic, shapes, and patterns questions.
