Black or Silver - AV Kit?
Old 09-06-2007, 2:04 PM   #1
4,907, Level: 16
Points: 4,907, Level: 16 Points: 4,907, Level: 16 Points: 4,907, Level: 16
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 16, Got 20
Ok so there we all are.............
researching, discussing kit, then putting our hard earned money down to buy some great AV we hope!
I would like to get the Toshiba HD e1 pretty soon. Only problem is that it comes in black (which can be good).
Then I think ok get a black reciever to match (any brand). But would this be too much black for the eye?
My living room is quite modern with some classic touches. Main thing is - walls are cream and carpet is brown/beidge. so fairly modern.
My plasma stand where all the gear would sit is glass with a silver finish cnetre part that holds it all thogether.
Now I would like to et everything silver - to match with the plasma (PX60 panasonic) and also owing to the fact everthing wont look to in your face. As black will look hard on soft colours. Silver should blend togther and you will look at the screen more then the kit.
What do you guys think? Black or silver?
Old 09-06-2007, 2:07 PM   #2
Mep Mep is online now
Conspicuous Member
Mep's Avatar
14,376, Level: 28
Points: 14,376, Level: 28 Points: 14,376, Level: 28 Points: 14,376, Level: 28
Thanks: Gave 442, Got 465
Re: Black or Silver - AV Kit?
Two of my set ups are black and one is silver. I by far prefer the 'professional' look of the black set ups but accept they don't look good with all decor.
I think in your case I would err for silver.
Old 09-06-2007, 2:12 PM   #3
7,477, Level: 20
Points: 7,477, Level: 20 Points: 7,477, Level: 20 Points: 7,477, Level: 20
Thanks: Gave 277, Got 192
silver all the way for me....
Old 09-06-2007, 3:00 PM   #4
4,907, Level: 16
Activity: 0.7%
I think Im definatly steering more toward silver.................
It basically blends into the back round more - but still looks the part.
If yo have dark furniture then you can easily get away with black.
Old 09-06-2007, 4:45 PM   #5
Pezerinno's Avatar
9,873, Level: 23
Points: 9,873, Level: 23 Points: 9,873, Level: 23 Points: 9,873, Level: 23
Thanks: Gave 163, Got 68
I much prefer black, I find silver a bit cheap looking (no offence to anyone with silver kit!)
Old 09-06-2007, 5:07 PM   #6
Conspicuous Member
shahedz's Avatar
13,120, Level: 27
Points: 13,120, Level: 27 Points: 13,120, Level: 27 Points: 13,120, Level: 27
Thanks: Gave 1,382, Got 722
Gotta say i prefer black, think it looks more expensive and classy
Old 09-06-2007, 5:29 PM   #7
2,475, Level: 11
Points: 2,475, Level: 11 Points: 2,475, Level: 11 Points: 2,475, Level: 11
Thanks: Gave 10, Got 6
the new pioneer amps are coming out in piano black! mmmmmmmm
Old 09-06-2007, 5:33 PM   #8
BrianC's Avatar
7,602, Level: 20
Points: 7,602, Level: 20 Points: 7,602, Level: 20 Points: 7,602, Level: 20
Thanks: Gave 80, Got 102
Depends on the finish more than the colour for me. A decent piano black gloss looks the business but the black on a £60 Alba mini system looks rubbish, same for silver.
Most of my kit is silver with the exception of my Wii (white) and my Sky HD (black) box, but its all different finishes and shades so none of it matches. My Xbox 360 is chrome, my Arcam amp is aluminium, my Denon dvd player is "titanium".
In your case I'd go for silver and try to buy everything from the same manufacturer or at least see it all together to see how close a match it is.
Old 09-06-2007, 5:52 PM   #9
John Watts's Avatar
7,074, Level: 20
Points: 7,074, Level: 20 Points: 7,074, Level: 20 Points: 7,074, Level: 20
Thanks: Gave 333, Got 83
Black. It will never go in or out of fashion like all the silver/gold/champagne/platinum/etc etc fads
Its a classic hi-fi/home cinema pre requisite and i'm sure when all the others have faded away it will live long and proud.
Black kit is class and thats permanant, others mentioned are the current form but that as we all know is temporay.
Old 09-06-2007, 7:14 PM   #10
4,907, Level: 16
Activity: 0.7%
interesting you say that.
This is my opinion. Both Black and silver dont go out of fashion. i think its more to do with the detail that goes onto the kit. For example most new kit that is black comes with white writing. This IMO gives the kit a freah look where a few years back majority of black kit was with gold writing.............
just some thoughts.....
Champagne definatly looks out dated. Platinum can also specially the old marantz gear.
Old 09-06-2007, 7:23 PM   #11
3,280, Level: 13
Points: 3,280, Level: 13 Points: 3,280, Level: 13 Points: 3,280, Level: 13
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 380, Got 1,194
As the woman who has to do the dusting black is my arch enemy and I'd choose silver no matter what for my house.
Old 09-06-2007, 7:41 PM   #12
Pezerinno's Avatar
9,873, Level: 23
This is of course the downside, I have to dust my kit every couple of days it seems. Also scratched show up more (not that I have any )
Old 09-06-2007, 9:28 PM   #13
Conspicuous Member
Mep's Avatar
14,376, Level: 28
so get Mr Jenn to dust it
Old 09-06-2007, 9:50 PM   #14
John Henry's Avatar
3,320, Level: 13
Points: 3,320, Level: 13 Points: 3,320, Level: 13 Points: 3,320, Level: 13
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 97, Got 38
Black, Black and Black.
Unless you are going for a arcam set up they do silver and black and one of the few that look good in silver.
Old 09-06-2007, 10:25 PM   #15
Conspicuous Member
overkill's Avatar
10,886, Level: 25
Points: 10,886, Level: 25 Points: 10,886, Level: 25 Points: 10,886, Level: 25
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 269, Got 681
Black. I couldn't believe it when silver (or brushed ali as it really is) came back in. It looks sooooooo cheap and nasty. Even high end amps still look tacky in ali.
Chox1988 (10-06-2007)
