Ambient Orb
Old 23-05-2007, 7:09 AM   #1
4,686, Level: 16
Points: 4,686, Level: 16 Points: 4,686, Level: 16 Points: 4,686, Level: 16
Thanks: Gave 2, Got 2
Ambient Orb
Does anyone else have an irrational want for one of these little glowing balls?
I can't even work out what I'd do with it, I just want one!
http://www.ambientdevices.com/cat/orb/orborder.html
I dont even think they work in the UK sigh.
Old 23-05-2007, 8:37 AM   #2
9,158, Level: 22
Points: 9,158, Level: 22 Points: 9,158, Level: 22 Points: 9,158, Level: 22
Thanks: Gave 34, Got 61
Re: Ambient Orb
Mathmos do a very similar one but it's rubber coated - you can chuck it at the wall to turn it on and off... or anything else you wish to throw it at
Old 23-05-2007, 9:47 AM   #3
Conspicuous Member
20,515, Level: 34
Points: 20,515, Level: 34 Points: 20,515, Level: 34 Points: 20,515, Level: 34
Activity: 9.8%
Activity: 9.8% Activity: 9.8% Activity: 9.8%
Thanks: Gave 85, Got 381
Re: Ambient Orb
I think its more the way that this thing reacts to data trends ie weather , stock market, etc.
You can build your own , its not that difficult I believe , just some LEDs that are programmed to modulate their intensity according to data provided from the net.
Old 23-05-2007, 10:08 AM   #4
9,158, Level: 22
Re: Ambient Orb
Ahh - should have looked at the link - there i was thinking it was a style thing
Old 23-05-2007, 6:54 PM   #5
4,686, Level: 16
Re: Ambient Orb
i wonder if i could configure it to connect to my credit card balance, although itd be bright red for a few years yet...
