Simple basic website required What software would you recommend
Old 21-05-2007, 3:49 PM   #1
Setenza's Avatar
23,213, Level: 37
Points: 23,213, Level: 37 Points: 23,213, Level: 37 Points: 23,213, Level: 37
Thanks: Gave 202, Got 235
I wish to plonk up about 4 pages of a simplistic nature.
Don't want any complex software. Just a simple small product, preferably with a design wizard that will generate the content and dump it ready for uploading.
Suggestions please.
Old 21-05-2007, 4:14 PM   #2
Conspicuous Member
pixelpixel's Avatar
24,058, Level: 37
Points: 24,058, Level: 37 Points: 24,058, Level: 37 Points: 24,058, Level: 37
Activity: 31.1%
Activity: 31.1% Activity: 31.1% Activity: 31.1%
Thanks: Gave 1,620, Got 1,182
Re: Simple basic website required What software would you recommend
Notepad.
Old 21-05-2007, 5:08 PM   #3
sbowler's Avatar
11,173, Level: 25
Points: 11,173, Level: 25 Points: 11,173, Level: 25 Points: 11,173, Level: 25
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 131, Got 497
My site, see my sig, is on freeweb and have found it easy to use.
Setenza (21-05-2007)
Old 21-05-2007, 5:16 PM   #4
Setenza's Avatar
23,213, Level: 37
Originally Posted by pixelpixel View Post
Notepad.
Oh tee hee, you techno purist you.
Old 21-05-2007, 5:51 PM   #5
Conspicuous Member
pixelpixel's Avatar
24,058, Level: 37
Activity: 31.1%
Saying I need a website is a bit vague! Any details regarding it. What do you need it to do? Host images or is it just content ?
Old 21-05-2007, 5:54 PM   #6
Setenza's Avatar
23,213, Level: 37
Some text and some images really. No more functionality than what MySpace can provide.
Old 21-05-2007, 6:17 PM   #7
6,748, Level: 19
Points: 6,748, Level: 19 Points: 6,748, Level: 19 Points: 6,748, Level: 19
Thanks: Gave 203, Got 225
acehtml is a freebie (I think) which would also do the job...
In all honesty though, you can't beat notepad for simple pages.
It's suprisingly easy to learn simple html, have a look here, here, and here.
Got any spare-time?
Old 21-05-2007, 6:32 PM   #8
Setenza's Avatar
23,213, Level: 37
I use to use Notepad for creating pages on the fly back in the late 90's. What I want to do is put up a few pages of a personal nature.
I have a copy of Dreamweaver but it's using a sledgehammer to crack a walnut.
I won't use MySpace co's of all the advertising.
Old 21-05-2007, 6:38 PM   #9
6,748, Level: 19
yeah dreamweaver is horrid.
I actually found learning html easier than learning dreamweaver.... I think they may have a problem there.
AceHTML and easyHTML are both worth googling.
Old 21-05-2007, 7:05 PM   #10
FruitBat's Avatar
6,293, Level: 18
Points: 6,293, Level: 18 Points: 6,293, Level: 18 Points: 6,293, Level: 18
Activity: 6.4%
Activity: 6.4% Activity: 6.4% Activity: 6.4%
Thanks: Gave 79, Got 243
Word is another option.
Old 21-05-2007, 7:16 PM   #11
brendan_dj's Avatar
18,847, Level: 33
Points: 18,847, Level: 33 Points: 18,847, Level: 33 Points: 18,847, Level: 33
Thanks: Gave 61, Got 117
Frontpage Express.
Old 21-05-2007, 8:22 PM   #12
12,594, Level: 26
Points: 12,594, Level: 26 Points: 12,594, Level: 26 Points: 12,594, Level: 26
Activity: 4.4%
Activity: 4.4% Activity: 4.4% Activity: 4.4%
Thanks: Gave 205, Got 941
Nvu, from those nice Mozilla people is a free Frontpage like HTML editor (without the non-standard code):
http://www.nvu.com
Old 22-05-2007, 11:21 AM   #13
Conspicuous Member
pixelpixel's Avatar
24,058, Level: 37
Activity: 31.1%
I started out on notepad then moved to homesite, that was then taken over my Macromedia and I have played with the new dreamweaver cs3. If your looking for some help let me know and I can code you what you want.
This is something I am currently working on, started a while ago but just waiting on the content. See here all my time was given for free.
Old 22-05-2007, 3:46 PM   #14
Setenza's Avatar
23,213, Level: 37
That's very good actually. I want a few pages and that's the format I'd like them in I may well take you up on your offer of assistance
Old 22-05-2007, 4:11 PM   #15
Keith Hurst's Avatar
11,043, Level: 25
Points: 11,043, Level: 25 Points: 11,043, Level: 25 Points: 11,043, Level: 25
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 338, Got 544
Have quick gander at my home page.. www.kjhurst.com
It was cobbled together using Notepad after a free download of a template from www.styleshout.com.
One way to do it.
KH
Old 22-05-2007, 4:18 PM   #16
Conspicuous Member
pixelpixel's Avatar
24,058, Level: 37
Activity: 31.1%
No worries would be glad to help, the website was less the 1hrs work. Its due to be redesigned shortly.
Old 22-05-2007, 7:07 PM   #17
11,125, Level: 25
Points: 11,125, Level: 25 Points: 11,125, Level: 25 Points: 11,125, Level: 25
Activity: 11.8%
Activity: 11.8% Activity: 11.8% Activity: 11.8%
Thanks: Gave 195, Got 151
Dreamweavers extremely annoying to use. I found it simpler in the end just opening notepad than using it.
Old 22-05-2007, 8:40 PM   #18
12,594, Level: 26
Activity: 4.4%
For a source of free templates, take a look at:
http://www.openwebdesign.org
