LOFT CONVERSION - What do I NEED?
Old 30-04-2007, 8:02 PM   #1
madman1178's Avatar
4,703, Level: 16
Points: 4,703, Level: 16 Points: 4,703, Level: 16 Points: 4,703, Level: 16
Thanks: Gave 35, Got 13
Question LOFT CONVERSION - What do I NEED?
Hello.
Moved into a new build 4 bed detached house back in January. Whilst putting all the boxes in the loft after unpacking, I noticed it was impressively large.
The main staircase runs up the middle of the house with ideal access to a new staircase leading to the loft going directly above from the small bedroom, meaning only a slight reduction in size for this room.
I worked out i could get 2 good sized rooms up their each coming off one side of the stairs. I used Google Sketchup to make a plan.
I am wanting to do a lot of the work myself to keep costs to a minimum but would want all the main stuff like the truss's removing and the roof and floor reinforcing professionally.
I was mainly wanting advice, and also wanted to know what planning permission and building regulations i would need. also what safety aspects to take into consideration, like automatic shutting doors and smoke alarms etc.
This need to be done a budget, so i will be doing alot of the work myself.
cheers
Ian
Old 01-05-2007, 2:51 PM   #2
eFGee's Avatar
2,002, Level: 10
Points: 2,002, Level: 10 Points: 2,002, Level: 10 Points: 2,002, Level: 10
Thanks: Gave 24, Got 14
Re: LOFT CONVERSION - What do I NEED?
If I were you, I'd get plans drawn up by an architect and get him to submit them for planning permission.
Old 01-05-2007, 3:21 PM   #3
Vnb Vnb is offline
2,998, Level: 12
Points: 2,998, Level: 12 Points: 2,998, Level: 12 Points: 2,998, Level: 12
Thanks: Gave 85, Got 94
Hi - as I understand it , you do not need planning but building regulations. This I think will cover structural integrity,fire escape windows and fire doors, insulation type etc. This is if you wish to use the rooms as bedrooms. If not and they are a hobby room you may not need some regulations.
Either way most councils produce a document.
You will need some professional advice with regards to floor and roof I would have thought.
Old 01-05-2007, 3:46 PM   #4
johnscarlet's Avatar
18,897, Level: 33
Points: 18,897, Level: 33 Points: 18,897, Level: 33 Points: 18,897, Level: 33
Activity: 20.9%
Activity: 20.9% Activity: 20.9% Activity: 20.9%
Thanks: Gave 225, Got 1,024
You might find some info on the planning portal , if your in England
Old 01-05-2007, 4:07 PM   #5
eFGee's Avatar
2,002, Level: 10
Building regs are just the code to which any building / adaption is built. As any potential loft conversion could look into a neighbours bedroom, garden, etc, I would have thought you would need planning. But I may be wrong.
Either way, an architect will be able to let you know.
Old 01-05-2007, 5:01 PM   #6
deadred's Avatar
5,171, Level: 17
Points: 5,171, Level: 17 Points: 5,171, Level: 17 Points: 5,171, Level: 17
Thanks: Gave 125, Got 46
A loft!
Old 01-05-2007, 5:06 PM   #7
3,306, Level: 13
Points: 3,306, Level: 13 Points: 3,306, Level: 13 Points: 3,306, Level: 13
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 31, Got 65
Originally Posted by deadred View Post
A loft!
Could'nt resist eh!
It may be worth calling some of the loft conversion specialist companies. Many do full and or part conversions that you can finish yourself. They will also be able to advise on whats needed re permisssion and regs etc.
Old 01-05-2007, 5:24 PM   #8
JagoPlasma's Avatar
12,664, Level: 27
Points: 12,664, Level: 27 Points: 12,664, Level: 27 Points: 12,664, Level: 27
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 847, Got 387
Originally Posted by Trent. View Post
Could'nt resist eh!
hes probably like me and doesnt have one!
hopefully will do soon tho as im buying my first house! was thinking of doing a loft conversion myself
Old 01-05-2007, 7:59 PM   #9
madman1178's Avatar
4,703, Level: 16
Thanks for all the help guys!!
especially to the guy who said "loft"
freakin genious. - glad you mentioned it mate, i had booked an appointment for a loft conversion company to come round tomorrow and start building a loft conversion in my downstairs toilet!
I thought they could go anywhere!
I'd better cancel it!
deadred (01-05-2007)
Old 01-05-2007, 9:20 PM   #10
4,230, Level: 15
Points: 4,230, Level: 15 Points: 4,230, Level: 15 Points: 4,230, Level: 15
Thanks: Gave 235, Got 189
Have a look at the link below.
It's a handout I had a part in producing before I retired.
Building Regs are the same wherever you are in England/Wales.
http://www.hyndburnbc.gov.uk/roundab...onversions.pdf
Old 01-05-2007, 10:21 PM   #11
deadred's Avatar
5,171, Level: 17
Glad i could help, anything else you need to know don't hesitate to ask!
Old 02-05-2007, 4:49 PM   #12
madman1178's Avatar
4,703, Level: 16
I was thinking of getting some decking in the garden too. Now i already have a garden, but no decking yet. what do you suggest?
Old 03-05-2007, 8:45 AM   #13
3,874, Level: 14
Points: 3,874, Level: 14 Points: 3,874, Level: 14 Points: 3,874, Level: 14
Thanks: Gave 36, Got 327
Start with a deck chair and then expand.
