Originally Posted by bones` Apparantly you are not allowed to touch the cable that comes from the outside and into your master socket. |
The important thing as far as the exchange is concerned is that your installation should present the right sort of load, so that the automated line tests pass. BT have also been concerned about the possibility of people inadvertently sticking high voltages on the line, risking damage to their equipment and engineers! This is why you aren't supposed to fiddle about with anything before the master socket (or the master socket itself, unless it is designed to allow you to add extensions).
Thats fair enough but someone has butchered mine. Basically they have cut it before it enters the house and spliced in an extension that runs off down the side of the house, then another cable runs inside to the master socket. So whats the problem?
I currently run my sky router off the extension which re-enters the property at the back bedroom. I have a lot of errors on my line so I thought I'd try the test socket but thats no use until I can sort out the wiring. Could the current setup be the cause of the errors?
It certainly doesn't sound right. There should only be a single master socket in the installation, and the extension wiring should come off that. Assuming your extension phone works normally (rings!), that must also be using a master socket in order to derive the ringing current. I suspect that could adversely affect the high frequency ADSL signals.
I assume you have microfilters on all your telephone equipment? That's the first thing to check, as well as seeing if the errors disappear when
all equipment is disconnected apart from your ADSL modem/router.
The cable they have used is only 4 core so possibly not up to standard.
Only 3 wires are actually used... I doubt that the cable is the source of your problems.
Would I be better off cutting the extensions off and joining some decent cable to the existing BT stuff then running that to the master socket? If so then whats the best method of joining the cable? They have used some clear connectors that dont seem to be re-usable. They have 1 wire in and 2 out.
Do the checks and test I suggested first. If you still have problems, I suggest replacing the extension socket with a normal one, and wiring it back to the master socket. We can discuss that later!
