Floodlights
Old 09-04-2007, 12:34 PM   #1
sjack
Posts: n/a
Floodlights
Not sure if this is the right place.
I need help with the IQ 500W Floodlight with PIR.
Here
Need the instructions or how to use the override feature.
Old 09-04-2007, 12:48 PM   #2
10,113, Level: 24
Points: 10,113, Level: 24 Points: 10,113, Level: 24 Points: 10,113, Level: 24
Thanks: Gave 77, Got 35
Re: Floodlights
If it's the same design as mine, you switch it on, then off and on again within three seconds to override.
