Originally Posted by RMCF Does anyone have ay experience of offset mortgages?
I have been hearing a lot about these recently and was wondering if it might be worth switching to one. I am sure there are terms and conditions as per usual but anything that would knock a year or two off the term would be helpful. |
You generally have to pay a higher rate of interest for offset mortgages - it's normally said that you need to have 50-60% of your mortgage offset to benefit. The higher your rate of tax, the less you need to offset with to benefit.
It all depends on how much you have to offset with. For example if a couple had an extra 500 quid a month to overpay with, they would probably be better to take a cheaper non-offset mortgage and putting the money in their cash ISAs, taking them to the 3000 quid limit each.
As has been mentioned
www.fool.co.uk has calculators and people who know a lot about these sorts of products.
(I think they're a good idea in principle, but I get a bit cross when their promotional blurb says 'When you offset money with our mortgage, your saving are effectively earning 6% tax free'. This is true, but it's a pretty optimistic way of putting it. If their mortgage was 15%, your savings would be 'earning' 15% interest by offsetting by that method of thinking. You have to imagine that when offsetting your savings are earning money at the rate of the cheapest normal mortgage, because that's the real alternative)
I've gone on a bit there - there are also normal mortgages which allow you to overpay - unless you've got stacks of cash these are probably the best way to go.
