how to convert dvd to divx
Old 28-12-2006, 10:34 PM   #1
10,349, Level: 24
Points: 10,349, Level: 24 Points: 10,349, Level: 24 Points: 10,349, Level: 24
Thanks: Gave 8, Got 42
Hi am looking to rip all my dvds onto my hard drive and them convert them to divx. out of you experinced computer boffins can anyone recommend me the best program software to rip my dvds onto my hard drive then convert them over to divx.
also what will be the best settings to use when converting to divx
many thanks
Old 28-12-2006, 11:09 PM   #2
Illustrious Member
Singh400's Avatar
32,618, Level: 44
Points: 32,618, Level: 44 Points: 32,618, Level: 44 Points: 32,618, Level: 44
Activity: 22.0%
Activity: 22.0% Activity: 22.0% Activity: 22.0%
Thanks: Gave 900, Got 2,125
Re: how to convert dvd to divx
AutoGK Very simple and easy.
Old 28-12-2006, 11:45 PM   #3
10,349, Level: 24
i cant seem to conver all the dvd to divx only 1 stage at a time, also says cant convert to divx as i dont have the installation?
there should be easier programs than this
Old 29-12-2006, 8:50 AM   #4
Ayub's Avatar
6,655, Level: 19
Points: 6,655, Level: 19 Points: 6,655, Level: 19 Points: 6,655, Level: 19
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 639, Got 466
or use "fairuse" to back up /convert YOUR OWNED COLLECTION as i have . Oh and its a free program.
http://www.fairusewizard.com/lang_en/
Easy to use and quick to encode. Job iz ze good von!
Old 29-12-2006, 3:01 PM   #5
Illustrious Member
Singh400's Avatar
32,618, Level: 44
Activity: 22.0%
You need to install the DivX codec yourself, but I would stick with XviD. You'll only be able to convert the actual movie itself into XviD (AVI), not menus etc.
Eurgh, tried FU. Didn't like it at all.
Old 29-12-2006, 4:13 PM   #6
Ayub's Avatar
6,655, Level: 19
Activity: 0.8%
each to their own i guess. i found it quite easy and simple to use with good results !
Old 29-12-2006, 6:51 PM   #7
10,349, Level: 24
what program do i first use to rip my dvd to the pc?
Old 29-12-2006, 6:59 PM   #8
Ayub's Avatar
6,655, Level: 19
Activity: 0.8%
http://www.videohelp.com/
Old 29-12-2006, 7:54 PM   #9
Illustrious Member
Singh400's Avatar
32,618, Level: 44
Activity: 22.0%
DVD Shrink, lol, you've got a long way to go yet. I thought you woulda known that!
Old 29-12-2006, 7:58 PM   #10
10,349, Level: 24
cool that video help is good
am going to use ripit4me to rip my dvds to my pc
Old 29-12-2006, 8:58 PM   #11
Ayub's Avatar
6,655, Level: 19
Activity: 0.8%
Your welcome.
Old 29-12-2006, 9:36 PM   #12
10,349, Level: 24
still cant get them to convert to divx once i ruipped them to my hard drive with either program
Old 29-12-2006, 10:09 PM   #13
Ayub's Avatar
6,655, Level: 19
Activity: 0.8%
Fair use will do it all?
Old 29-12-2006, 10:24 PM   #14
10,349, Level: 24
it takes a long time still got 1 hour 50 to go.
cant be bothered doing this for my 112 dvd collection lol
either that or get a faster pc
Old 31-12-2006, 3:30 PM   #15
DVD-Man's Avatar
7,867, Level: 21
Points: 7,867, Level: 21 Points: 7,867, Level: 21 Points: 7,867, Level: 21
Activity: 7.2%
Activity: 7.2% Activity: 7.2% Activity: 7.2%
Thanks: Gave 303, Got 429
doom9.org is your friend!
Liam
