Who's the best ISP at the moment
Old 29-10-2006, 11:34 PM   #1
6,212, Level: 18
Points: 6,212, Level: 18 Points: 6,212, Level: 18 Points: 6,212, Level: 18
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 111, Got 61
As header, i'm with Zen currently, but at £34.99 per month for unlimited use, i'm sure some providers can better this.
Any ideas folks ??
2mb service.
Old 30-10-2006, 1:11 AM   #2
39,746, Level: 48
Points: 39,746, Level: 48 Points: 39,746, Level: 48 Points: 39,746, Level: 48
Thanks: Gave 276, Got 1,589
Re: Who's the best ISP at the moment
Havent been through the site in a while, but always worth checking out http://www.adslguide.org.uk/ for some idependent reviews.
Old 30-10-2006, 8:06 AM   #3
johnny70's Avatar
4,263, Level: 15
Points: 4,263, Level: 15 Points: 4,263, Level: 15 Points: 4,263, Level: 15
Thanks: Gave 130, Got 71
I have been with AOL for the last 8 years, one connection at work, one at home, can't fault them, i know people slag of there software, but at the end of the day you don't have to use it, just the connection. we have a 8mb connection at work £34.99 a month unlimited downloads, and a 1mb connection at home for £17.99 unlimited, but most of the time its at over 2mb.
JOHNNY
Old 30-10-2006, 8:14 AM   #4
t-force's Avatar
8,477, Level: 22
Points: 8,477, Level: 22 Points: 8,477, Level: 22 Points: 8,477, Level: 22
Thanks: Gave 54, Got 68
I've been with Nildram for 3 and a half years now, and I can't fault them. I've had to ring tech support 3 times in that period, and they've always got the problem sorted for me (twice at my end, once at theirs) within 2 hours - including on a Saturday.
They're a little more than some, but they certainly back it up with excellent performance and support.
Old 30-10-2006, 10:23 AM   #5
Conspicuous Member
Crocodile's Avatar
15,118, Level: 29
Points: 15,118, Level: 29 Points: 15,118, Level: 29 Points: 15,118, Level: 29
Activity: 12.5%
Activity: 12.5% Activity: 12.5% Activity: 12.5%
Thanks: Gave 408, Got 1,147
It's the same old quality vs quantity issue. There are plenty of cheaper deals out there but it seems you need to be "lucky" to find them beneficial. I'm also with Zen but would be very reluctant to change. Last year I went through the exercise of evaluating ISPs for my mother. After much research I went for Freedom2surf at £14.99/month for 2mbs/2Gb. Great - for about 6 weeks when they were swallowed up by Pipex. Poor speeds, frequent downtime, non-existent support, etc., etc.
If you can live with 20Gb/month you could knock a tenner off your monthly bill with Zen's 8mbs Max Active package.
Old 30-10-2006, 11:09 AM   #6
Mr_Wistles's Avatar
9,875, Level: 23
Points: 9,875, Level: 23 Points: 9,875, Level: 23 Points: 9,875, Level: 23
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 131, Got 686
I used to be with Pipex who were excellent until they started capping.
I am now with Demon 2mb uncapped and I think I pay £21.99 (I don't do the bills)
Old 30-10-2006, 12:43 PM   #7
Digger's Avatar
8,197, Level: 21
Points: 8,197, Level: 21 Points: 8,197, Level: 21 Points: 8,197, Level: 21
Thanks: Gave 232, Got 200
Installed Zen's Active 8000 as mentioned above its the £24.99 20 gb product. Excellent speeds and top notch support so far altho only had it a couple of weeks
Old 30-10-2006, 6:01 PM   #8
Cynthia 7
Posts: n/a
My son recommended me to use Zen when I first had a computer (five years ago). I pay £24.99 a month Home 500. "Which" magazine placed them at No.l.
My husband, who rarely uses the computer, said we should look for a cheaper option but I dug my heels in and said it's worth paying the extra. Nearly all my friends have changed their ISPs several times through bad service. I have never had any problems with them. When I first started I rang them a few times with problems (turned out it was my lack of computer skills!). They went to a lot of trouble and time to help. Their monthly newsletter is always very interesting too. I'm staying with them.
Old 30-10-2006, 6:15 PM   #9
WelshBluebird's Avatar
10,786, Level: 24
Points: 10,786, Level: 24 Points: 10,786, Level: 24 Points: 10,786, Level: 24
Thanks: Gave 41, Got 146
While AOL are a good ISP atm (one of the few unlimited ISP's without a FUP), they are in the process of being bought by CPW, so be very wary about joining AOL
Old 30-10-2006, 9:03 PM   #10
4,114, Level: 15
Points: 4,114, Level: 15 Points: 4,114, Level: 15 Points: 4,114, Level: 15
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 304, Got 57
I'm with Nildram at the moment....... has anyone tried Madasafish, looks like a good deal?
http://www.madasafish.com/services/b...d_max.asp?r=bg
