problem with XP logging in
Old 08-10-2006, 11:01 AM   #1
Conspicuous Member
shahedz's Avatar
13,117, Level: 27
Points: 13,117, Level: 27 Points: 13,117, Level: 27 Points: 13,117, Level: 27
Thanks: Gave 1,382, Got 722
HI Chaps,
i am having problems logging into XP, before it would go onto the user page, and i would choose my name and enter the password to log on. Now when i turn on the computer, a window appears with just my name ( I am the administrator) , i enter the password and log in,
i need the user page so other users of my computer can log onto thier stuff, any ideas how?
Old 08-10-2006, 11:47 AM   #2
3,478, Level: 13
Points: 3,478, Level: 13 Points: 3,478, Level: 13 Points: 3,478, Level: 13
Thanks: Gave 117, Got 48
Re: problem with XP logging in
Hi Shahedz,
I would take a look in the Control Panel - log in as administrator, ..Start ...Settings ...Control Panel. Select User Accounts icon.
This should now detail all accounts set up on the screen. I'd hazard a guess you need to select 'change the way users log on or off' and then make sure 'use the welcome screen' is ticked.
Think that should sort you out.
shahedz (08-10-2006)
