I've destroyed my wireless broadband!
Old 29-08-2006, 12:02 PM   #1
6,584, Level: 19
Points: 6,584, Level: 19 Points: 6,584, Level: 19 Points: 6,584, Level: 19
Thanks: Gave 15, Got 11
I've been having problems with my wireless, ie, getting no signal! So i bought a booster ariel.
Basically it wouldn't just fit, given that my linksys router opperates a closed system, so i decided to pull it apart and see if i could do a bit of modification.
But now i've jsut destroyed it. I basically have two bits of frayed cables just touching each other and no signal!!!
Does anyone know how to connect the two cables, and whether i can or do i need an adapter??
Please help me, I don't like not having the internet!!!
Old 29-08-2006, 12:26 PM   #2
mjn mjn is offline
18,264, Level: 32
Points: 18,264, Level: 32 Points: 18,264, Level: 32 Points: 18,264, Level: 32
Activity: 4.4%
Activity: 4.4% Activity: 4.4% Activity: 4.4%
Thanks: Gave 218, Got 612
Re: I've destroyed my wireless broadband!
Shouldn't laugh...but when people who know nothing about something, take said item apart, and make the situation worse......well, it makes me chuckle.
Old 29-08-2006, 12:29 PM   #3
6,584, Level: 19
It's electrical, it can't be too hard. I'll work it out eventually, i'm sure, just wanted to know if there was a tried and tested method, save myself hours of trying different stuff.
Next time i do it I'll have lernt from my experience.
Old 29-08-2006, 1:16 PM   #4
10,059, Level: 24
Points: 10,059, Level: 24 Points: 10,059, Level: 24 Points: 10,059, Level: 24
Activity: 26.1%
Activity: 26.1% Activity: 26.1% Activity: 26.1%
Thanks: Gave 561, Got 1,053
You've destroyed your router. Don't believe the AOL marketing "wireless broadband" doesn't exist.
Old 29-08-2006, 1:18 PM   #5
Steven's Avatar
61,783, Level: 60
Points: 61,783, Level: 60 Points: 61,783, Level: 60 Points: 61,783, Level: 60
Activity: 33.1%
Activity: 33.1% Activity: 33.1% Activity: 33.1%
Thanks: Gave 2,014, Got 4,412
So before coming on this forum to find out whether it was a software problem, which with routers + wireless setups; it is often the case, you took it apart?
You're just gonna have to go back to the old modem....until you buy another router
Old 29-08-2006, 1:24 PM   #6
6,584, Level: 19
You make a good point, perhaps i was a little hasty...
Old 29-08-2006, 2:22 PM   #7
7,818, Level: 21
Points: 7,818, Level: 21 Points: 7,818, Level: 21 Points: 7,818, Level: 21
Activity: 4.8%
Activity: 4.8% Activity: 4.8% Activity: 4.8%
Thanks: Gave 425, Got 577
Still, look on the bright side, you made us laugh.
Old 29-08-2006, 2:24 PM   #8
Setenza's Avatar
23,213, Level: 37
Points: 23,213, Level: 37 Points: 23,213, Level: 37 Points: 23,213, Level: 37
Thanks: Gave 202, Got 235
I applaud your resolve to modify the unit, but I must admit you may have been a little rash. Did you not consider taking advise or a obtaining a wiring diagram first?
Old 29-08-2006, 7:52 PM   #9
Chris Muriel's Avatar
15,699, Level: 30
Points: 15,699, Level: 30 Points: 15,699, Level: 30 Points: 15,699, Level: 30
Activity: 11.1%
Activity: 11.1% Activity: 11.1% Activity: 11.1%
Thanks: Gave 510, Got 629
It's more than just "electrical". There are radio frequency (RF) considerations ; we're talking about 2.4 GHz not 50 Hz mains!
You could try posting some close up pictures of the PCB so that any microstriplines , baluns etc. can be seen.
Chris Muriel, Manchester
Old 29-08-2006, 8:41 PM   #10
9,504, Level: 23
Points: 9,504, Level: 23 Points: 9,504, Level: 23 Points: 9,504, Level: 23
Thanks: Gave 20, Got 73
Mate, for the relative low cost of these toys today i would throw it away buy new and have done with it, sorted.
Avoid screwdrivers and superglue as (humorously) being practical and being realistic appear not to be bedfellows.
Old 29-08-2006, 8:46 PM   #11
mickrick's Avatar
6,611, Level: 19
Points: 6,611, Level: 19 Points: 6,611, Level: 19 Points: 6,611, Level: 19
Thanks: Gave 2, Got 21
Indeed. UTV Internet are advertising a "free wireless modem" with their service.
Old 29-08-2006, 8:52 PM   #12
mickrick's Avatar
6,611, Level: 19
Well I don't know what model of linksys router you have, but they all look pretty much the same to me anyway. Have a look at this site. It gives detailed instructions on how to disassemble/reassemble a linksys WRT54G router. This is the model I have and I have had reason to visit this site myself following a failed firmware flash.
Old 29-08-2006, 8:57 PM   #13
Setenza's Avatar
23,213, Level: 37
I love it when you talk techno
Old 30-08-2006, 5:43 AM   #14
Reign-Mack's Avatar
11,029, Level: 25
Points: 11,029, Level: 25 Points: 11,029, Level: 25 Points: 11,029, Level: 25
Thanks: Gave 1,264, Got 219
Smh!
Old 30-08-2006, 10:45 PM   #15
Setenza's Avatar
23,213, Level: 37
Ever thought of giving yourself a tripple bypass rather than have a doctor do it
Old 31-08-2006, 1:08 PM   #16
6,584, Level: 19
All is sorted, i routed the new ariels wire directly into the connection on the motherboard and everything works perfectly....
I'm lying, i bought a new one off Amazon, working perfectly!
Old 31-08-2006, 8:20 PM   #17
Reign-Mack's Avatar
11,029, Level: 25
LMFAO
Old 31-08-2006, 8:43 PM   #18
15,699, Level: 30
Activity: 11.1%
I might be interested in trying to resurrect the old broken one.
Old 01-09-2006, 8:48 AM   #19
6,584, Level: 19
Sorry mate, it's been promised to medical science, ie I decided to destroy it completly now, just to see what it all does... basically it just sits there not doing much.
which is slightly annoying because before it was transfering lots of wisdom through the wonder of the air. It's a shadow of its former self now...
Maybe we should say a prayer for it???
Cheers for all the advice guys!!!
