Scandisk Alternative?
Old 12-08-2006, 7:48 PM   #1
Reign-Mack's Avatar
11,029, Level: 25
Points: 11,029, Level: 25 Points: 11,029, Level: 25 Points: 11,029, Level: 25
Thanks: Gave 1,264, Got 219
Is there an alternative to scandisk?
I decided to run a surface scan on one of my hardrive its been doing it for over 9 hours and has only reached 5%
Is there a faster alternative to Microsoft's effort as I do not want to be stuck only using the lap top for the next 6 or 7 days...
Old 12-08-2006, 8:00 PM   #2
unique's Avatar
18,529, Level: 32
Points: 18,529, Level: 32 Points: 18,529, Level: 32 Points: 18,529, Level: 32
Activity: 4.1%
Activity: 4.1% Activity: 4.1% Activity: 4.1%
Thanks: Gave 51, Got 1,111
go to www.download.com (or downloads) run by cnet, they have loads of tools and stuff, freeware and trials
mind, if your stuck on 5% after so long, it could be a sign that the drive is knackered
Old 12-08-2006, 8:13 PM   #3
Reign-Mack's Avatar
11,029, Level: 25
sorry I wanted somebody to recomenf a program they have used themselves... already know about cnet. Once somebody names a product I will got the full program not the trial version.
and yes parts of the drive are knackered which is why I am running a surface scan. but thanks
Old 12-08-2006, 9:18 PM   #4
unique's Avatar
18,529, Level: 32
Activity: 4.1%
norton utilities has a scandisc program. i've used it in the past and found it pretty good. haven't used it on xp/ntfs tho. i can't think of any other major scan disc type programs
Old 12-08-2006, 9:20 PM   #5
Illustrious Member
Singh400's Avatar
32,635, Level: 44
Points: 32,635, Level: 44 Points: 32,635, Level: 44 Points: 32,635, Level: 44
Activity: 19.9%
Activity: 19.9% Activity: 19.9% Activity: 19.9%
Thanks: Gave 901, Got 2,136
Which OS are you running? Because scandisk isn't available in XP no more.
Old 12-08-2006, 10:42 PM   #6
unique's Avatar
18,529, Level: 32
Activity: 4.1%
if you rightclick on your drive in exporer, click on tools and you have "error checking" which is prettymuch scandisc under a new name
Old 12-08-2006, 11:02 PM   #7
Illustrious Member
Singh400's Avatar
32,635, Level: 44
Activity: 19.9%
Yeah I know about that. But I was specifically referring to the old scandisk found in Windows ME.
Old 13-08-2006, 6:54 AM   #8
Reign-Mack's Avatar
11,029, Level: 25
Many Thanks
and yes Singh like unique says I am running XP and I am using scandisk, I call a spade a spade.
Old 13-08-2006, 8:52 AM   #9
fizl's Avatar
4,740, Level: 16
Points: 4,740, Level: 16 Points: 4,740, Level: 16 Points: 4,740, Level: 16
Activity: 6.8%
Activity: 6.8% Activity: 6.8% Activity: 6.8%
Thanks: Gave 182, Got 255
Diskeeper Pro is very good for scanning and defragging. Much much better than XP for doing it. You have to remember that the speed will be very different depending on whether your disk is formatted to FAT or NTFS, as FAT takes forever
Shaz
