browser advice
Old 12-08-2006, 7:20 PM   #1
Conspicuous Member
MrFurious's Avatar
25,652, Level: 39
Points: 25,652, Level: 39 Points: 25,652, Level: 39 Points: 25,652, Level: 39
Activity: 8.0%
Activity: 8.0% Activity: 8.0% Activity: 8.0%
Thanks: Gave 616, Got 391
browser advice
when i run a speed test with adsl.org i get this message "Your web browser does not support frames or is currently configured not to display frames"
how do i correct this please
Old 12-08-2006, 7:38 PM   #2
Setenza's Avatar
23,213, Level: 37
Points: 23,213, Level: 37 Points: 23,213, Level: 37 Points: 23,213, Level: 37
Thanks: Gave 202, Got 235
What web browser are you using first of all?
Old 12-08-2006, 7:40 PM   #3
Conspicuous Member
MrFurious's Avatar
25,652, Level: 39
Activity: 8.0%
internet explorer 6
Old 12-08-2006, 7:47 PM   #4
Setenza's Avatar
23,213, Level: 37
Unless you've recently changed some of the setting within IE6 itself, this error message may be due to a problem with the the coding of the website you've visited.
You can always go to "tools", "internet options", "advanced" and then select "reset all defaults". Then check the site again.
I'll try the site myself with IE7 (beta) then with Mozilla Firefox and see if I get any errors.
Old 12-08-2006, 9:24 PM   #5
Illustrious Member
Singh400's Avatar
32,630, Level: 44
Points: 32,630, Level: 44 Points: 32,630, Level: 44 Points: 32,630, Level: 44
Activity: 22.0%
Activity: 22.0% Activity: 22.0% Activity: 22.0%
Thanks: Gave 901, Got 2,134
I'm gonna assume you mean http://www.adslguide.org.uk/ - do you have Java installed?
Old 12-08-2006, 9:33 PM   #6
Conspicuous Member
MrFurious's Avatar
25,652, Level: 39
Activity: 8.0%
yes ans yes i have java
Old 12-08-2006, 9:56 PM   #7
Illustrious Member
Singh400's Avatar
32,630, Level: 44
Activity: 22.0%
Do you have any security applications? Like Ad Muncher? McAfee? Norton? Anything that connects to the internet, protects, shields you from ads/virus/whatever.
In the meanwhile you can use this site to run a speed test.
Old 12-08-2006, 10:12 PM   #8
Conspicuous Member
MrFurious's Avatar
25,652, Level: 39
Activity: 8.0%
yeah i have mcafee, i used that site and i got 959kbps which is great as it means orange have finally sorted my problems out,i was getting 200kbps for months!!!
Old 12-08-2006, 11:01 PM   #9
Illustrious Member
Singh400's Avatar
32,630, Level: 44
Activity: 22.0%
Ah right, yes. I did google the issue, and McAfee does something to iframes. Try disabling it and returning to adsulguide.org.uk
Old 12-08-2006, 11:23 PM   #10
Conspicuous Member
MrFurious's Avatar
25,652, Level: 39
Activity: 8.0%
hmm doesnt seem to do anything,thanks for your help though mate
