Go Back   AVForums.com > Lifestyle Topics > General Chat
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
Old 27-07-2006, 11:47 AM   #1 (permalink)
Thanks: Gave 1, Got 3
Improving insulation in a terraced house
As most of you are aware utility bills have increased/will be increasing dramatically, I want to make sure I have the best insulation I can have/afford for my end-of-terrace house.
I am fully double glazed (much of it quite new), I have a brand new combi/condensing boiler for heating and water, but I think my loft could do with some new insulation - is it worth splashing out on something expensive and can anyone think of something I can do to make sure I am insulated properly.
Fluke is offline   Reply With Quote
Old 27-07-2006, 12:08 PM   #2 (permalink)
Thanks: Gave 4, Got 111
The stuff you buy in rolls from B&Q/Homebase etc. is as good as anything I reckon. It will tell you on the pack how thick it should be. Don't try and install it on a hot day - it can be hard work!
Just make sure you don't block any ventilation under the eaves (if you have any there) otherwise your roof could rot from the inside out.
GW43 is offline   Reply With Quote
Old 27-07-2006, 1:57 PM   #3 (permalink)
mjn
Thanks: Gave 122, Got 414
When we moved in, we replaced the insulation in the loft, before we put the floor down. And old stuff has been there for years, and had become compressed and starting to fall apart. However in this hot weather, the house is now roasting! Heating hasn't been on since late Feb!
Sony STRDB930, Rotel RMB-1075, Sony KDL-40X2000U, HD HTPC, B&W CDM 1NT, CNT & SNT, MF A3 24-bit DAC, SkyHD, TSU7000 ProntoPro NG, QED cables
Follow my PC Case mod project here: http://www.hardforum.com/showthread.php?t=1189553
mjn is offline   Reply With Quote
Old 27-07-2006, 2:05 PM   #4 (permalink)
JohnG's Avatar
Thanks: Gave 1,159, Got 583
I was just about to say, I'm paying the price for having good insulation - it's like an oven in my house now
I know the meaning of life, it doesn't help me a bit
JohnG is offline   Reply With Quote
Old 27-07-2006, 2:14 PM   #5 (permalink)
av2diefor
Posts: n/a
Should'nt be, a well insulated house should stop the heat .
Think of a flask
Old 27-07-2006, 2:16 PM   #6 (permalink)
mjn
Think of a flask
I've yet to see a flask with windows.......
Old 27-07-2006, 2:19 PM   #7 (permalink)
JohnG's Avatar
Indeed, the sun shines through the windows and heats the place up, then there's no way for the heat to escape. My bedrooms face South and so the wall there tends to act like a giant storage heater
Old 27-07-2006, 2:27 PM   #8 (permalink)
Thanks: Gave 32, Got 145
same here with my bedroom
For insulation, do you have any cavity walls? whats the insulation like in them? theres some foam you can pump into the cavity that helps a lot with insulation. But obv an older house might be brick all round. What about a revolving door? the Gherkin building in london has to open its vents near the top as the revolving doors so a great job of keeping hot air in
ush flynn is offline   Reply With Quote
Old 27-07-2006, 2:33 PM   #9 (permalink)
av2diefor
Posts: n/a
Aye canny.... I asked for that.
Same thing really though, single glazing will let in more heat than double glazing, same applies in the loft without insulation.
Becomes a point where , would you be any cooler without insulation at all due to the latent heat not being able to escape?
Old 27-07-2006, 2:34 PM   #10 (permalink)
Thanks: Gave 54, Got 126
I'm sure i read somewhere that cavity wall insulation is not recommended as it does not allow the house to "breath" and can cause damp, a bit like putting cladding on external walls
LG 50PQ3000 Plasma, Yammy A595 Amp,B&W CC3 centre Kef Coda 7 fronts
Mission 73 surrounds, Pioneer DV400 DVD Player (multi-region)
Crystal Xbox (modded with X3 + 250gig HDD)
Virgin Cable & Broadband
Kebabhead is offline   Reply With Quote
Old 27-07-2006, 2:36 PM   #11 (permalink)
JohnG's Avatar
My house was built with some kind of cavity wall insulation in as is the norm with a lot of the modern timber frame type buildings. It just gets far too hot in the summer.
Old 27-07-2006, 2:37 PM   #12 (permalink)
mjn
With the climate changing as such, the way we insulate our homes will change.
I mean, when was the last time we had a proper cold winter in England? I can't really remember any in the last 10 years, and even longer since a good snow fall.
Old 27-07-2006, 2:40 PM   #13 (permalink)
pave's Avatar
Thanks: Gave 272, Got 179
Be careful when laying the insulation,wear a mask and make sure you have checked for cables
pave is offline   Reply With Quote
Old 27-07-2006, 2:43 PM   #14 (permalink)
It's not so much the cold it's our damp climate that is the problem
Old 27-07-2006, 3:12 PM   #15 (permalink)
mjn
I thought we're in a drought season?
house, improving, insulation, terraced
