Password protecting a Hdd?
Old 12-07-2006, 3:13 PM   #1
Tiesto's Avatar
5,361, Level: 17
Points: 5,361, Level: 17 Points: 5,361, Level: 17 Points: 5,361, Level: 17
Thanks: Gave 11, Got 1
Hi all , is there any software that can password protect a Hdd on a pc. ?
Running three drives here and want to make one either invisible in My computer/disk drives , or password protected.
Any usefull links or advice.
Old 12-07-2006, 3:17 PM   #2
Moosh's Avatar
8,455, Level: 22
Points: 8,455, Level: 22 Points: 8,455, Level: 22 Points: 8,455, Level: 22
Thanks: Gave 823, Got 429
Hi Tiesto
Many, many moons ago I used a product called ScramDisk. It used to be free and was very good. It would create an encryted partition on your harddrive and you could only access it using a password. The partition acted like any other partition in Explorer and worked seamlessly.
The commercial products is called DriveCrypt and you can see details of it at the following sites:
http://www.securstar.com/
http://www.drivecrypt.com/home.html
Moosh
Old 12-07-2006, 3:20 PM   #3
Moosh's Avatar
8,455, Level: 22
Just seen this as well:
http://www.truecrypt.org/
And it is open source!
Moosh
Old 12-07-2006, 3:27 PM   #4
mjn mjn is offline
18,257, Level: 32
Points: 18,257, Level: 32 Points: 18,257, Level: 32 Points: 18,257, Level: 32
Activity: 4.5%
Activity: 4.5% Activity: 4.5% Activity: 4.5%
Thanks: Gave 217, Got 609
yeah, encryption is best method.
But depends how far you want to go? If you just want the HDD to disappear from explorer, then don't give that HDD a drive letter.
If you want to restrict access, then use security options on folders.
Old 12-07-2006, 5:17 PM   #5
Mr Cat's Avatar
16,833, Level: 31
Points: 16,833, Level: 31 Points: 16,833, Level: 31 Points: 16,833, Level: 31
Thanks: Gave 21, Got 66
I think its just to hide the porn from his missus!
