calculating mortage interest?!
Old 21-06-2006, 4:01 PM   #1
45,470, Level: 52
Points: 45,470, Level: 52 Points: 45,470, Level: 52 Points: 45,470, Level: 52
Activity: 21.2%
Activity: 21.2% Activity: 21.2% Activity: 21.2%
Thanks: Gave 378, Got 854
Can someone help work out which is better?
I have some options when remortaging with Nationwide:
tracker:
Pay £499 and get 0.13% *below* BOE base rate for 2 years
Pay nothing and get 0.27% *above* BOE base rate for 2 years.
How do I calculate what that 0.4% difference equates to on a £150k mortgage?
Another option was
Pay £399 and get 0.18% *above* BOE base rate for the full length of the mortgage. Tied in for 5 years but no penalty if switching to a fixed rate before then. Does that sound good?
I'm currently paying 0.04% above base but its running out in August. Of course I'll check other options too
Old 21-06-2006, 4:21 PM   #2
ChrisPy1
Posts: n/a
0.4% as a fraction is 0.004, so assuming it's an interest only mortgage, then the difference in payments per year is
0.004 * £150000 = £600 PER YEAR so you would be better off paying the £499 as you'll still be £700 better off after two years...........
Old 21-06-2006, 4:23 PM   #3
Vnb Vnb is offline
2,997, Level: 12
Points: 2,997, Level: 12 Points: 2,997, Level: 12 Points: 2,997, Level: 12
Thanks: Gave 85, Got 94
You need to use a mortgage calculator - loads on the web http://www.cml.org.uk/cml/consumers/...mortcalculator
eg 150k @4.4% = £834 month on repayment over 25 years (the term does make a small difference)
150k @4% =£800
£34 a month over 2 years is £816 saving you £317
regards,
vnb
Old 21-06-2006, 4:46 PM   #4
shay0's Avatar
8,802, Level: 22
Points: 8,802, Level: 22 Points: 8,802, Level: 22 Points: 8,802, Level: 22
Thanks: Gave 166, Got 505
The other alternative is to ask the lender. If they can't tell you exactly how much you'd pay & save, then its a poor do
