American style fridge/freezers
Old 07-06-2006, 12:05 PM   #1
PAH PAH is offline
5,777, Level: 18
Points: 5,777, Level: 18 Points: 5,777, Level: 18 Points: 5,777, Level: 18
Activity: 3.7%
Activity: 3.7% Activity: 3.7% Activity: 3.7%
Thanks: Gave 12, Got 61
Moving house and need a new fridge/freezer. Seen those american style ones in Comet/Currys etc and want to know if there's a model that allows you to fill the water/ice dispenser by hand rather than needing to have it plumbed in and drawing water from the normal supply?
Intend placing whatever I get at the other side of the kitchen and don't want a pipe running around but really like the idea of having cold (drinkable!) water and ice on tap, especially for the summer. Also want to be able to use bottled water rather than the filth that comes out of the taps.
Downloaded a user guide for the Samsung range and it does appear one of the models (at least) allows the water dispenser to be hand-filled, but unfortunately as the guide covers all models with various sections flagged as optional I can't work out which models provide this facility.
Any help much apppreciated, otherwise I'll just stick to a normal fridge/freezer as there are one or two models with water dispensers, but not ice.
Old 07-06-2006, 12:20 PM   #2
Mac Man's Avatar
9,703, Level: 23
Points: 9,703, Level: 23 Points: 9,703, Level: 23 Points: 9,703, Level: 23
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 220, Got 240
any particular reason for not wanting to plumb it in (besides taste)?
Most plumbed in ones come with a filter that will remove most of the crap taste. You can bet your boots that the day you need ice you'll realise you haven't filled it up recently. And with one that you fill by hand the water will need to be changed regularly (if not used up everyday) as it's basically standing water. So sticking bottled water in may not be ideal. I think you may find that they are more hassle than plumbing mains water in. Especially if the supply can be pre-treated.
We bought a Maytag from Currys (at a good price I thought) in that black crackle finish. It makes a huge amount of ice which can be dispensed either crushed or cubed. The ice is made constantly and is always full. There must a 6 litre ice capacity in there. Enough for the most demanding barbecue/party.
i was amazed by how much we use it, now that the facility is there. especially at the moment
Old 07-06-2006, 12:35 PM   #3
PAH PAH is offline
5,777, Level: 18
Activity: 3.7%
Maybe part of me was hoping I could sneak some beer in the dispenser and have nice cold draught on tap for the footy
Main reason I was wondering is so I can get the fridge and worry about the plumbing later if possible as I'd need to route the pipe through the back of several units and along the skirting or something, so not a straight forward plug in and go proposition.
I suppose if they come with a proper filter that's replacable/cleanable then that would go some way to making the tap water drinkable without risking limescale issues ruining the fridge.
Old 07-06-2006, 12:37 PM   #4
2,504, Level: 11
Points: 2,504, Level: 11 Points: 2,504, Level: 11 Points: 2,504, Level: 11
Thanks: Gave 0, Got 3
The pipe that supplies the water is tiny - about 5mm dia - so it's very easy to fit and hide away. As stated above, the filter does a good job in removing the tap water taste and can be replaced in a matter of minutes. The Samsung we have has a indicator that tells you when to change the filter.
Old 07-06-2006, 12:53 PM   #5
Mac Man's Avatar
9,703, Level: 23
Activity: 2.7%
We have a standard 'mains' pipe that goes under the floorboards to the fridge location and there is a 1.5m connecting pipe to the actual unit.
Our filter is easily replaceable and has a light to warn it needs changing.
The water itself isn't chilled as it comes straight off the mains. But it's filtered and the ice is just there. I actually thought our ice maker was bust at first. Until I realised it was going to take a few hours for it to create enough ice to be dispensed
But it's ace and I love the convenience - as do the rest of the family. The Maytag seemed a very good buy... £900. Most Maytags are usually £1500 upwards. I think this may have been a new entry level model for the UK market as there were a few internet sites selling them.
It seems you are paying a lot for special finishes on some of these fridges - especially some of the Samsung and LG models which appear to be identical except that some have mirrored doors or stainless steel all round.
A lot of the cheaper units have very plain sides, which won't look to great if the fridge is going to be free standing.
Old 07-06-2006, 1:03 PM   #6
29,695, Level: 42
Points: 29,695, Level: 42 Points: 29,695, Level: 42 Points: 29,695, Level: 42
Thanks: Gave 69, Got 316
Upright freezers are so expensive to run compared to chest freezers. Every time you open the door, all the cold air inside the freezer falls to the floor, and all the hot air from the ceiling rushes in.
Old 07-06-2006, 1:12 PM   #7
PAH PAH is offline
5,777, Level: 18
Activity: 3.7%
Yes, noticed there's supposedly some models with 'flaps' on the front to access part of the fridge (though haven't seen any in the shops so far) so the whole door doesn't need opening. Plus if there's a dispenser then the fridge doesn't need opening to get out drinks, providing water is posh enough!
Old 07-06-2006, 1:15 PM   #8
Mac Man's Avatar
9,703, Level: 23
Activity: 2.7%
Ours has an 'A' rating and is a damn sight more useable than the old chest freezer we used have
Old 07-06-2006, 1:40 PM   #9
Vnb Vnb is offline
2,997, Level: 12
Points: 2,997, Level: 12 Points: 2,997, Level: 12 Points: 2,997, Level: 12
Thanks: Gave 85, Got 94
We have one of these - the samsung RL39WBMS1
http://www.comet.co.uk/comet/html/cache/30_122831.html
This is filled by hand. We use a britta water filter thing to fill it - no limescale or other issues. Had it for 2 years ,very happy with it.
regards,
vnb
Old 07-06-2006, 1:49 PM   #10
Drd Drd is offline
Drd's Avatar
3,928, Level: 14
Points: 3,928, Level: 14 Points: 3,928, Level: 14 Points: 3,928, Level: 14
Thanks: Gave 124, Got 169
That and the fact the kids don't fall into it when they raid it for a lolly.
I've the opposite problem PAH,I've got the plumbing ready,been there for 6 years,but my fridge and freezer refuse to give up.
Old 07-06-2006, 2:28 PM   #11
PAH PAH is offline
5,777, Level: 18
Activity: 3.7%
Good luck waiting for your current one to pack in, my old folks have had the same chest freezer for the last 30 odd years! Doubt it's anywhere near class A rated though.
That Samsung (RL39WBMS1) is similar to the ones I've seen that are more like ordinary fridge/freezers but with the water dispenser facility. Maybe I'm too lazy to bash my own ice out or I like the style of the american ones (ok, pose factor!) but one of these types is certainly the fall-back option. Noticed they don't recommend putting anything except pure water in the dispenser, which is a shame, though I'm sure I've seen one in PowerHouse or somewhere with a pipe and proper tap for hooking up a mini-keg or something!
I can't believe how hard it is deciding on a fridge!
Old 07-06-2006, 2:57 PM   #12
Vnb Vnb is offline
2,997, Level: 12
The samsung has a big ice bucket, where you empty the trays into - a twiddly knob thing that drops the ice into the bucket.
I would have thought putting anything other than water in is not a good idea - I think it would stain and you'll be cleaning it forever.
Old 07-06-2006, 3:18 PM   #13
Beobloke's Avatar
3,824, Level: 14
Points: 3,824, Level: 14 Points: 3,824, Level: 14 Points: 3,824, Level: 14
Thanks: Gave 4, Got 58
Pah! Sod water - what you want's a Barfly beer fridge!!
http://www.barfly.ca/english/intro.html
Old 07-06-2006, 5:44 PM   #14
Mr_Wistles's Avatar
9,871, Level: 23
Points: 9,871, Level: 23 Points: 9,871, Level: 23 Points: 9,871, Level: 23
Activity: 3.8%
Activity: 3.8% Activity: 3.8% Activity: 3.8%
Thanks: Gave 131, Got 683
I just bought the Samsung yank one.
The fridge is massive but I was suprised at how small the freezer part is, the ice machine takes up about 1/4 of the space.
I can post some pictures of it if you like.
Old 07-06-2006, 6:31 PM   #15
PAH PAH is offline
5,777, Level: 18
Activity: 3.7%
Seen them in the shops. The Samsung model range is a bit confusing to say the least. There's about 20 models and on the surface not a lot of difference between them all. The Samsung website doesn't clarify things much either.
Still the prices are pretty good, starting around £700, and half the reason I got interested in them in the first place, you can spend at least half that on a decent 'normal' fridge/freezer.
The lack of freezer space doesn't worry me as it'll encourange healthier eating than just living off frozen food and bunging it in the microwave. Not to mention plenty of space to store all the drinks. I know several people that run two fridges, one for everyday stuff and one for the important stuff (booze and drinks!). So overall these big mothers are probably more efficient
Old 08-06-2006, 8:19 AM   #16
10,113, Level: 24
Points: 10,113, Level: 24 Points: 10,113, Level: 24 Points: 10,113, Level: 24
Thanks: Gave 77, Got 35
Make sure you can plan a route into your kitchen for one of these beasts. We ended up taking ours down the side alley and into next doors' garden then over the fence and in through the patio doors. The delivery blokes said that one in three end up going back to the shop 'cos they can't get them in...
Old 08-06-2006, 8:25 AM   #17
Mac Man's Avatar
9,703, Level: 23
Activity: 2.7%
That is sooooo true. the 2 guys from Currys took one look at our 35 degree slope that is our driveway and said 'no chance mate' and scarpered.
Currys then sent out the 'A' team of 3 really big blokes who managed to manhandle the thing into the house via the conservatory. No way will one of these fit through an average front door.
Old 08-06-2006, 2:26 PM   #18
Assured Advertiser
RICKYJ's Avatar
15,938, Level: 30
Points: 15,938, Level: 30 Points: 15,938, Level: 30 Points: 15,938, Level: 30
Activity: 9.8%
Activity: 9.8% Activity: 9.8% Activity: 9.8%
Thanks: Gave 1,024, Got 704
Have any of you got the Samsung RS21DCNS (http://www.dixons.co.uk/martprd/stor...ry_oid=-27925), I have ordered one of these for delivery next Sat (as we move in to our new place next Fri), and was just wondering whether it comes with the water catridge, and how long the mains supply is?
Thanks for any help you can give.
Oh, by the way, I ordered it last bank holiday weekend at a reduced price of £599, and with an emailed discount code which got me £40 off the order, so only paid £559 for it (inc del)
Ricky
THX Certified Video Professional Level I & II Certified Calibrator
Kalibrate is proud to be an Assured Advertiser on AVforums.
Supplying carefully selected AV Products...
Contact us on sales@chromapure.co.uk, 01883460225 or 07947007644
Old 08-06-2006, 3:49 PM   #19
PAH PAH is offline
5,777, Level: 18
Activity: 3.7%
Fortunately for me it can be taken down the side of the house and through the patio doors into the kitchen so relatively easy.
Wondering with the water shortages the local authorities keep harping on about whether it's best to run the feeder pipe outside into a rain collector, less aggro than running a pipe round the kitchen. If the feed needs to be pressurised rather than a pump sucking it in then I guess a gerbil on a wheel over the top of the pipe will do. Yes I've been down to the pub for lunch and just got back
Old 09-06-2006, 8:15 AM   #20
29,695, Level: 42
The 'A' rating refers to the insulation. I'm sure it's very economical as long as you don't open the door
Old 11-06-2006, 9:39 PM   #21
darren_eaf's Avatar
3,272, Level: 13
Points: 3,272, Level: 13 Points: 3,272, Level: 13 Points: 3,272, Level: 13
Thanks: Gave 47, Got 34
What big wimps!!! I do deliveries of these and other big things like range cookers with just one other person.
They will fit through a front door, as the actual fridge doors come off really easily and then they are the same size depth wise as a normal fridge.
Old 12-06-2006, 10:23 PM   #22
2,038, Level: 10
Points: 2,038, Level: 10 Points: 2,038, Level: 10 Points: 2,038, Level: 10
Thanks: Gave 0, Got 10
Anyone who looks at a side by side American style FF and thinks the freezer is small should check out the actual capacity and compare it to a normal fridge freezer. They are WAY bigger then they look, even alowing for the ice maker.
I've got my eye on a nice Samsung with a door in the fridge door if we have a closing down sale.
We had one that a customer bought two years ago and it sat in our warehouse until a few weeks ago! Everyone had their eye on it in case the customer cancelled it. The staff price had gone down to £350....
And as Darren says, the doors on the Samsung can be taken off in a couple of minutes with a philips screwdriver. I've done deliveries of these and some of the horror stories...
Old 13-06-2006, 3:55 PM   #23
Cynthia 7
Posts: n/a
We bought a Samsung RS21 JLBL(Baltic Blue Glass finish) at the beginning of the year. It had originally been ordered from Ogormans (and is still listed there) but Samsung discontinued this Blue glass finish. I got it elsewhere on the net and a bit cheaper.
We just have a small run of pipe from the sink unit round the skirting board. Tricky for you if you have doors to cross with the pipe.
The cold, filtered water tastes delicious. As I don't like tea I used to drink weak orange squash all the time or coffee. Now I just drink the water and lots of it, much healthier for me. The ready made ice with just a press of the button is excellent too, crushed or cubed.
When we had the appliance delivered the delivery man just literally dumped it at the door (I was out). My husband asked if he and the delivery man could wheel it (it was on a pallet) into the garage but the surly guy refused although he had been given a good tip. I came home to find it outside, in a large cardboard box; it was raining and my husband was inside reading the paper. I was really furious and found large thick polythene sheets in the garage (used for decorating). I tried to dry it and then I had to mount a step ladder to put it on the fridge freezer box and find bricks to anchor it down. Then find clothes pegs to anchor the sides together. My husband was really in the doghouse! It stayed outside for two and a half weeks until B & Q came to install it!
Amazingly it was perfect. The kitchen door had to be removed because of the layout of the kitchen cupboards. I love the look of it, the ice and water. The fridge part isn't as big as our old larder fridge and the vegetable drawers are a bit too deep. The -5 degrees C drawer is excellent as this keeps meat about a week longer than normal without freezing it properly.
Tesco's make a water cooler (about £70 plus) for which you buy 5 litre (I think) bottles of water from supermarkets. Maybe this may be easier for you.
