can water...
Old 23-05-2006, 10:13 AM   #1
Mr Cat's Avatar
16,833, Level: 31
Points: 16,833, Level: 31 Points: 16,833, Level: 31 Points: 16,833, Level: 31
Thanks: Gave 21, Got 66
can water...
...be organic..?
the reason I ask is that I read it cannot be - if this is the case, then can anything be truely organic..? except maybe to fit in with government guidelines?
Old 23-05-2006, 10:22 AM   #2
6,416, Level: 19
Points: 6,416, Level: 19 Points: 6,416, Level: 19 Points: 6,416, Level: 19
Thanks: Gave 33, Got 148
depends. I reckon if you collected it yourself then its pretty organic. I highly doubt anything you can buy in the shops has JUST been filtered
Old 23-05-2006, 10:23 AM   #3
Steve_P's Avatar
6,940, Level: 19
Points: 6,940, Level: 19 Points: 6,940, Level: 19 Points: 6,940, Level: 19
Thanks: Gave 95, Got 93
'Organic' - Do you mean chemistry definition? then no
Or do you mean 'marketing spin definition'? e.g. happy chickens running around a field as opposed to boxed in cages in an industrial shed... In which case, I dunno but I doubt it could be classed as organic. I suppose you could have categories:
Water bottled from a natural source with no additives.
Water bottled from a natural source with additives.
Water bottled from a non natural source.
S.
