did you have other stuff plugged in to the surge protector when the computer powered off? if you did and they stayed on then its the computer......if the surge protector went off and obviously the other items did too then its the power socket on the wall has problems....
if you didnt have other stuff plugged in, try plugging something else in and see what happens next time the puter shuts down....
as a by the by, dunno what surge protector you got, but Belkins Gold ones are very good, 7 socket one can be had for around £25-35 depending on where you get it from, its useful because you can run phone line thru it, TV coaxial cable thru it and also your network cable if you use one.....as well as mains plugs for equipment of course..heh
if it turns out to be the computer, most things have already been mentioned i think, give it a clean, get a temp monitor for it, make sure the fans at the back can kick out the air easily, make sure the connection between the lead and the PSU in the computer is solid, if there is a front intake fan, make sure that is working ok etc.....if all this is ok, then try new graphics drivers, strange but graphics cards often screw computers up..lol
