Problem with Ipod Shuffle
Old 04-05-2006, 1:00 PM   #1
Mr_Wistles's Avatar
9,875, Level: 23
Points: 9,875, Level: 23 Points: 9,875, Level: 23 Points: 9,875, Level: 23
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 131, Got 687
As always I am in need of some IT knowledge.
Whenever I plug my ipod shuffle in to my pc, the cpu usage goes to 100% and it becomes impossible to do anything.
Any suggestions?
Old 04-05-2006, 1:18 PM   #2
Conspicuous Member
Ultima's Avatar
12,312, Level: 26
Points: 12,312, Level: 26 Points: 12,312, Level: 26 Points: 12,312, Level: 26
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 701, Got 696
Does this happen using all USB ports?
Martin
Old 04-05-2006, 1:38 PM   #3
Mr_Wistles's Avatar
9,875, Level: 23
Activity: 3.4%
No, only that one.
Old 04-05-2006, 1:56 PM   #4
Conspicuous Member
Ultima's Avatar
12,312, Level: 26
Activity: 0.7%
Originally Posted by Russell_Piper
No, only that one.
Give this a try, go into
Control Panel
System
Hardware Tab
Device manager
Universal Serial Bus Controllers
and delete/uninstall all the devices (just the USB ones )
Aftre that right click on you computer at the top of your devices list and left click "scan for hardware changes".
Win xp will then refind the USB ports/controllers and set them up again.
See if this helps.
P.s. I am assuming you are running Win XP of course.
Regards
Martin
Old 04-05-2006, 5:19 PM   #5
Ayub's Avatar
6,657, Level: 19
Points: 6,657, Level: 19 Points: 6,657, Level: 19 Points: 6,657, Level: 19
Activity: 0.7%
Thanks: Gave 639, Got 466
Any suggestions?
Russ i had the problem. You may be plugging it into a usb1 it works but takes ages. Try a usb2 if that does not work. Try the firewire cable.
