SATA > IDE adapters - are they available?
Old 31-01-2006, 4:51 PM   #1
mickrick's Avatar
6,611, Level: 19
Points: 6,611, Level: 19 Points: 6,611, Level: 19 Points: 6,611, Level: 19
Thanks: Gave 2, Got 21
I hope this doesn't get moved to the Xbox forum as it is a lot bigger than that, even though it is my main concern at the minute.
Anyway, I would like to put a 300Gb hdd into my Xbox, and I can get a SATA one from work. But I cannot find a cable or adapter that will convert a SATA drive to be used on an ide channel, although there are plenty that work the other way round.
Does anyone know if these are available and where I might get one? I had a lot of trouble getting 3 SATA to usb adapters from the states and even then the supplier wouldn't ship them directly to me so I had to get them delivered to an address in the states first and then on to the uk, so in this country would be preferable.
Old 31-01-2006, 5:57 PM   #2
tom_painter85's Avatar
3,044, Level: 12
Points: 3,044, Level: 12 Points: 3,044, Level: 12 Points: 3,044, Level: 12
Activity: 0.5%
Activity: 0.5% Activity: 0.5% Activity: 0.5%
Thanks: Gave 4, Got 2
you can get SATA-IDE connectors from Maplin for cheap(ish) - took a while to find them when i was looking, but i'll post a linky when i find them again
HTH
Tom
Old 31-01-2006, 6:04 PM   #3
3,044, Level: 12
Activity: 0.5%
maplin link:
http://www.maplin.co.uk/module.aspx?...36036&doy=31m1
not as cheap as i thought though...
Old 31-01-2006, 11:25 PM   #4
5,966, Level: 18
Points: 5,966, Level: 18 Points: 5,966, Level: 18 Points: 5,966, Level: 18
Thanks: Gave 10, Got 27
Originally Posted by tom_painter85
maplin link:
That'll get an IDE HD to work on a SATA motherboard - from what I know the OP won't get one the other way I'm afraid... doesn't exisit.
Old 01-02-2006, 2:10 PM   #5
3,044, Level: 12
Activity: 0.5%
Red face
oh...
sorry 'bout that then!
Old 01-02-2006, 2:37 PM   #6
retired member
21,535, Level: 35
Points: 21,535, Level: 35 Points: 21,535, Level: 35 Points: 21,535, Level: 35
Thanks: Gave 4, Got 217
They definitely do exist - it's finding them that's the problem.
www.dataduplication.co.uk sell them, but it wouldn't fit in the Xbox for the purpose you require it for. There are cheaper ones on fleabay, but again, it wouldn't fit inside.
