Looked on the website.... v good.. not really a particular help
It is a hall, however only has one switch
Tried the old unit again, and it works fine
I CONCLUDE: The unit is DUFF!!!!
Thanks for the help, and pleaseee
Originally Posted by craynerd
Just to clarify it has no dimmer attached!
Chumpy-what do you mean when you talk about ring main?
...basically, there was a blue, brown and green only out of the roof, and identical on the light fitting...one would presume you connect them directly...i did, but no avail!?
You really should not being doing this wiring!!!! Get someone in who knows what to do, or we will be reading your obituary next week
give over...They will be asking for a degree to wipe your own arse soon!!!
