Dell only void the warranty if you use things Dell dont sell......so if you buy the memory from dell and fit it yourself then your warranty should still be valid...if you buy it from somewhere else (even if its teh same memory) then it wont be valid....
personally i cant say anything bad against Dell....have had 4 PC's from them, two of them still running good and well, the first got struck by lightening (and check this, the HDD actually remained intact! just everything else in the box got fried..lol), the second was the insurance replacement, which only went down because i overloaded the PSU by putting in too many things (was still learning about computers at the time..lol) such as an extra HDD, CD-RW, much more powerful graphics card, sound card, doubled the memory...plugged in a bunch of USB stuff...lol..poor thing lasted a while then went phut one day....heh....
any cheap PC you buy will be difficult to upgrade as most cheap PC's use boards with built in graphics and sound, so they have no AGP or PCI-Ex16 slots to upgrade with, only normal PCI slots which nowadays rules out graphics upgrades....the memory slots are normally all being used when you buy, so unless it supports larger MB memory modules you cant upgrade, the CPU could probably be changed, but even then, as with Dell and their motherboards, you might find that difficult or not worth the risk....
also the PSU's are usually pretty poor.......
so buy wherever you get the best deal if your looking at a few hundreds worth, but Dell will probably last longer and be more durable......and hey, people moan about Dells customer service (which the one time i used i found no problems with), so how many people do you see moaning about Dixons/PC World type shops after sales service when the puter breaks down? (unless of course you took out the super duper top flight extended warranty that cost as much as the computer...heh)...a hell of a lot more people moan about their service!.........its only when you spend much more and go to companies that produce specialist rigs like Alienware etc that you find they might be a good alternative to a Dell.....(altho personally my 8400 is a damn fine machine from Dell and was happily the equivelant of an Alienware that cost the same and didnt even come with the monitor that a friend of mine had...in fact i did one better, my 6800GTO graphics card overclocks to 6800 Ultra level.....his 6800GT kept on failing over 400/1050)
