+R/+RW discs - where to buy?
Old 09-08-2005, 8:57 PM   #1
7,808, Level: 21
Points: 7,808, Level: 21 Points: 7,808, Level: 21 Points: 7,808, Level: 21
Thanks: Gave 14, Got 8
I need to get some discs has anybody got any tips on which ones to buy or where to get them?
Old 09-08-2005, 9:02 PM   #2
Conspicuous Member
shahedz's Avatar
13,120, Level: 27
Points: 13,120, Level: 27 Points: 13,120, Level: 27 Points: 13,120, Level: 27
Thanks: Gave 1,382, Got 722
i always buy mine from www.svp.co.uk
have found them brilliant and the cheapest!
Old 09-08-2005, 9:34 PM   #3
Preeminent Member
Razor's Avatar
88,790, Level: 72
Points: 88,790, Level: 72 Points: 88,790, Level: 72 Points: 88,790, Level: 72
Activity: 47.6%
Activity: 47.6% Activity: 47.6% Activity: 47.6%
Thanks: Gave 2,109, Got 3,669
ditto
Old 09-08-2005, 9:45 PM   #4
Illustrious Member
JohnG's Avatar
41,473, Level: 49
Points: 41,473, Level: 49 Points: 41,473, Level: 49 Points: 41,473, Level: 49
Activity: 13.5%
Activity: 13.5% Activity: 13.5% Activity: 13.5%
Thanks: Gave 2,202, Got 1,080
SVP get my vote every time, great prices and very helpful people.
Old 10-08-2005, 6:21 AM   #5
Garrett's Avatar
80,356, Level: 69
Points: 80,356, Level: 69 Points: 80,356, Level: 69 Points: 80,356, Level: 69
Activity: 25.3%
Activity: 25.3% Activity: 25.3% Activity: 25.3%
Thanks: Gave 216, Got 728
Cool
Same here SVP, they have a very fast delevery as well.
Old 10-08-2005, 7:17 AM   #6
3,266, Level: 13
Points: 3,266, Level: 13 Points: 3,266, Level: 13 Points: 3,266, Level: 13
Thanks: Gave 15, Got 14
I recently did another scout around for better places. I went back to SVP in the end.
Old 10-08-2005, 8:10 AM   #7
7,808, Level: 21
That's the kind of monopoly I like!
Cheers Guys
Old 10-08-2005, 8:42 AM   #8
7,808, Level: 21
I need them for a DVD recorder. I guess the 4x,8x,16x are all to do with PC drives. Which ones are best for me?
Old 10-08-2005, 9:23 AM   #9
General Skanky's Avatar
17,672, Level: 32
Points: 17,672, Level: 32 Points: 17,672, Level: 32 Points: 17,672, Level: 32
Thanks: Gave 24, Got 31
When researching buying a new DVD RW Drive, I came across www.cdfreaks.com
They all seem to be potty about Taiyo Yuden discs as being the very best available across the board.
SVP sell them.
Old 10-08-2005, 11:44 AM   #10
Conspicuous Member
overkill's Avatar
10,886, Level: 25
Points: 10,886, Level: 25 Points: 10,886, Level: 25 Points: 10,886, Level: 25
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 269, Got 681
www.cd-rmedia.co.uk are pretty competitive.
Old 10-08-2005, 12:35 PM   #11
5,966, Level: 18
Points: 5,966, Level: 18 Points: 5,966, Level: 18 Points: 5,966, Level: 18
Thanks: Gave 10, Got 27
Depending on what I want i'll check those mentioned above plus
www.neodiscs.com
www.bigpockets.co.uk
Old 10-08-2005, 2:20 PM   #12
w3dal's Avatar
8,167, Level: 21
Points: 8,167, Level: 21 Points: 8,167, Level: 21 Points: 8,167, Level: 21
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 303, Got 155
Originally Posted by Razor
ditto
Same here SVP for the last 12 months. Excellent Service and good prices too.
Dal
Old 10-08-2005, 2:31 PM   #13
4,828, Level: 16
Points: 4,828, Level: 16 Points: 4,828, Level: 16 Points: 4,828, Level: 16
Thanks: Gave 2, Got 1
svp for the last 2 years ,no hassle
Old 10-08-2005, 6:13 PM   #14
7,808, Level: 21
Guys,
If I want them for a DVD recorder does it matter whether I go for 4x,8x or 16x?
Old 10-08-2005, 8:29 PM   #15
w3dal's Avatar
8,167, Level: 21
Activity: 1.4%
Originally Posted by the_sanguine
Guys,
i dont have a dvd recorder - what does it burn at
i wouldnt of thought it matters. my pioneer drive in my PC burns any speed fine upto 8x
A ritek dye is always a good sign - plus verbatim do good discs.
currently using datawrite Titanium in a spindle tub of 50 done about half so far and no coasters.
Dal
Old 11-08-2005, 3:28 PM   #16
7,808, Level: 21
It doesn't say but it's not a copier or anything so I guess it only records in real time
Old 11-08-2005, 6:05 PM   #17
17,672, Level: 32
If the disc itself is important then you need the services of http://www.dvdinfopro.com/
A handy prog that will actually tell you who made the disc regardless of the logo.
The tub of 25 DVD-R on Tescos shelves for example, were made by Mitsubishi Chemicals, that when you search around on the web make quite a few others and are of a very good standard.
It's important as naturally, anything you want to keep you really dont want to deteriorate over time. Remember laser rot etc?
Old 12-08-2005, 12:24 PM   #18
6,837, Level: 19
Points: 6,837, Level: 19 Points: 6,837, Level: 19 Points: 6,837, Level: 19
Thanks: Gave 5, Got 1
Was going to recommend www.blankdiscshop.co.uk, but then realised that they are SVP! Always had good results with Ritek discs from them.
Old 12-08-2005, 4:10 PM   #19
7,808, Level: 21
OK, now another dumb question....
If I record with a +R DVD recorder but don't fill the disc up, can you record on the remaining space later?
