CCTV & recording advice needed
Old 02-06-2005, 11:23 PM   #1
4,612, Level: 16
Points: 4,612, Level: 16 Points: 4,612, Level: 16 Points: 4,612, Level: 16
Thanks: Gave 6, Got 0
Hey all
need your advice... i want to install CCTV camera in the office to make it a little more secure during the day and watch over the shopfront window during closed hours. so i purchase the following...
if i want to record the image at least 3 days worth before erasure, what sort of equipment do i need? Do i need one of these Time-Lapse Vcrs? is there a better solution? Any models/equipment you can recommend?
Any advice would be appreciated!
Thank you!
Fais
Old 02-06-2005, 11:33 PM   #2
JagoPlasma's Avatar
12,664, Level: 27
Points: 12,664, Level: 27 Points: 12,664, Level: 27 Points: 12,664, Level: 27
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 847, Got 387
buy a visix from everfocus, you can hook upto four sources to them and it is very high quality, it has removable hard drives so you can put bigger hard disks in for more storage
Old 05-06-2005, 12:36 PM   #3
Eminent Member
Tejstar's Avatar
126,891, Level: 86
Points: 126,891, Level: 86 Points: 126,891, Level: 86 Points: 126,891, Level: 86
Thanks: Gave 408, Got 993
I'm interested in doing something like this too, so if anyone has any further advice i'd be most grateful!
