ebay API
Old 06-07-2012, 2:52 PM   #1
Thanks: Gave 1,542, Got 424
ebay API
Hiya,
Does anyone know if ebay have an API you can use to embed the shopping cart on your website.
Basically website lists products, when you add them to your cart, it adds it to the ebay cart and when your continue to pay it does it all through ebay?
Old 06-07-2012, 3:38 PM   #2
Conspicuous Member
Dancook's Avatar
Thanks: Gave 2,490, Got 1,375
If they don't, maybe you could consider google checkout.
ldoodle (06-07-2012)
Old 06-07-2012, 4:14 PM   #3
Thing is, just finished a website for a mate, and his company have been using ebay for a while to sell their products so no point in re-inventing the wheel.
Old 06-07-2012, 4:15 PM   #4
darkmavis's Avatar
Thanks: Gave 16, Got 151
What have you used to build the site?
Old 06-07-2012, 4:44 PM   #5
Err, Notepad++ (ASP.NET 4)
Old 06-07-2012, 4:59 PM   #6
darkmavis's Avatar
you could wrap the shop into a page..
PHP: Supported Protocols and Wrappers - Manual
