Originally Posted by DPinBucks Sorry, I thought Neil & I had made that clear.
Switch it off.
Let's say it takes half an hour to warm your house from cold, and you normally get up at 07:30. Then set it to come on at 07:00. If you go to bed at 22:30, then set it to go off at 22:00. Adjust the times with experience. If necessary, get a timer which allows you to make different settings for weekends, when you might get up and go to bed later. Also, if the house is empty during the working day, get a two-level timer and treat the empty period the same as overnight. Generally in my experience, hot water timing need be the same as heating, but that's a matter of personal requirements.
Anything else is waste. |
That's the theory. In practice, as I stated earlier, we found no difference between having the heating on "timed" for morning and evening, and having it on all day. That was comparing gas useage over a 3 year period prior to the change in timer setting and a further 2 year period after.
Clearly, there are other factors to take into account such as boiler (and radiator) efficiencies at different tempertures. You can also get temperature over swings caused by the radiators being very hot, the thermostat going off, but the latent heat continuing to heat the room beyond the set temperature.
I'm not sure of the exact mechanisms involved, but it's not quite so simple as the "basic physics".
