Good way to display your fave films?
Old 21-11-2009, 12:13 AM   #1
cas398's Avatar
6,038, Level: 18
Points: 6,038, Level: 18 Points: 6,038, Level: 18 Points: 6,038, Level: 18
Thanks: Gave 201, Got 192
There was a thread in the 360 section where people would post their game collections but I can't find it.
Some people used this application or something to create a picture which looked like a shelf with the actual games on it.
I'm looking to do this for my fave movies but I don't know if that thing does it for movies or just games, or even what it is
Basically I want a nice looking picture with say my fave 20 movies on it, I would have posted this in the movie section but like I said I have only seen this application used for games.
Or do you know of something similar I can do other than create a slideshow in photobucket which I don't fancy doing?
Old 21-11-2009, 1:37 AM   #2
3,225, Level: 13
Points: 3,225, Level: 13 Points: 3,225, Level: 13 Points: 3,225, Level: 13
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 6, Got 8
No problem
For windows: Mediaman MediaMan - Professional Organizer Software for Books, Music, Videos, and Games
For mac: Delicious Libary 2 Delicious Library 2
Both have the nice bookshelf effect :D
Both are good, easy to insert your dvds (they do CDs/games/books too) and have the ability to either search amazon or other image sources for the picture&info or you can scan the barcode of the DVDs
Edit: And you can also save your libary & save fancy html versions for the web etc and also txt versions
cas398 (21-11-2009)
Old 23-11-2009, 1:22 AM   #3
cas398's Avatar
6,038, Level: 18
I don't seem to be able to use it, do you have to install a server or something like this says? MediaMan - Setup Guide for MediaMan Library
