Fixings for plasterboard?
Old 14-11-2009, 8:00 PM   #1
Matt_C's Avatar
26,953, Level: 40
Points: 26,953, Level: 40 Points: 26,953, Level: 40 Points: 26,953, Level: 40
Activity: 50.0%
Activity: 50.0% Activity: 50.0% Activity: 50.0%
Thanks: Gave 266, Got 659
What sort of fixings should I use on plasterboard? My walls plasterboard with a cavity behind before the brickwork, and I want to mount my rear surround speakers (Mission M7DS, weigh about 2 and a half Kg each I think) but not sure what fixings to use?
Likewise, I have a metal picture frame I also wanna hang. On the other walls, where pictures have been hung (these fixings were there when I moved in) are metal things that sit in the plasterboard and a screw turns into them. Seems a little hardcore for pictures, but then, the frame isn't that light, so maybe I should be using something like that?
Anyone advise me, as I no nothing about plasterboard! I've only ever fixed stuff to proper brickwork in the past, with proper rawl plugs etc
Old 14-11-2009, 8:19 PM   #2
Battle's Avatar
10,722, Level: 24
Points: 10,722, Level: 24 Points: 10,722, Level: 24 Points: 10,722, Level: 24
Activity: 7.2%
Activity: 7.2% Activity: 7.2% Activity: 7.2%
Thanks: Gave 106, Got 396
Re: Fixings for plasterboard?
You can get these screws with a plastic bit attached to them that as you turn the screw the plastic open out at the back which forms a "T" behind the plasterboard to hold it in place.
These should be fine for a picture frame but you may need something more substantial for speakers.
Matt_C (15-11-2009)
Old 14-11-2009, 8:22 PM   #3
11,864, Level: 26
Points: 11,864, Level: 26 Points: 11,864, Level: 26 Points: 11,864, Level: 26
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 486, Got 1,100
The plasterboard is fixed to wood battens. For the speakers which are fairly heavy, I suggest you find where the wood battens are and fix the speaker mountings using wood screws.
Tapping the plasterboard wall with your finger will indicate where the battens are.
Of course, do not mount anything directly above a power socket!
Matt_C (15-11-2009)
Old 14-11-2009, 8:33 PM   #4
7,549, Level: 20
Points: 7,549, Level: 20 Points: 7,549, Level: 20 Points: 7,549, Level: 20
Thanks: Gave 69, Got 273
These are jobbies.
Metal RediDrivas 35mm Pack of 100 - Screwfix.com, Where the Trade Buys
Matt_C (14-11-2009)
Old 14-11-2009, 8:37 PM   #5
Matt_C's Avatar
26,953, Level: 40
Activity: 50.0%
No battens anywhere near where I want the speakers
Old 14-11-2009, 8:40 PM   #6
Matt_C's Avatar
26,953, Level: 40
Activity: 50.0%
Originally Posted by deckingman View Post
Those look like what's in there already! Think they'll do for 2.5Kgs speakers?
Old 14-11-2009, 8:43 PM   #7
7,549, Level: 20
No probs with 2.5kg speakers. Stronger than the plaster board itself. I've fixed heavier things with them. I guess you can get them in DIY places as well as Screwfix. Don't get the plastic version though.
Matt_C (15-11-2009)
Old 14-11-2009, 9:15 PM   #8
stevefish69's Avatar
9,655, Level: 23
Points: 9,655, Level: 23 Points: 9,655, Level: 23 Points: 9,655, Level: 23
Thanks: Gave 866, Got 371
I use something similar but the Tox plugs act differently depending on the thickness of the plasterboard / type of material. They open up like regular rawlplugs on thick material, form a knot behind the board on another or open up in the form of a cross behind the board.
I have about 16 of these holding my Panny on my plasterboard wall, and IIRC only picked up 4 holes in the actual wooden stud. I can hang off the bracket and it does not budge at all. I'm a damn lot heavier than my Plasma too, so doubt if it will ever come down like that dodgy advert
They are an industrial type plug with pretty big screws. They are available in Clerkenwell screws and cost about £10 for 100 plugs and screws which makes them about 1000% cheaper than B&Q
IMO those metal screw type plasterboard fittings have always failed in my house so i'd advise against them
Matt_C (15-11-2009)
Old 14-11-2009, 9:20 PM   #9
3,216, Level: 13
Points: 3,216, Level: 13 Points: 3,216, Level: 13 Points: 3,216, Level: 13
Thanks: Gave 36, Got 224
I would use the redidrivas type for hanging your pictures (they are okay) but for the speakers i would use this type http://www.screwfix.com/prods/18266/...3mm-Pack-of-10
John....
Matt_C (15-11-2009)
Old 14-11-2009, 11:34 PM   #10
BandWidthJunkie's Avatar
3,101, Level: 13
Points: 3,101, Level: 13 Points: 3,101, Level: 13 Points: 3,101, Level: 13
Thanks: Gave 192, Got 115
These are expensive but brilliant, I have a TV in the kitchen attached to a cavity plaster board wall. They fix into the brick behind the cavity!
Rigifix Drywall Anchor M6 Pack of 4 - Screwfix.com, Where the Trade Buys
Matt_C (15-11-2009)
Old 15-11-2009, 12:25 AM   #11
Davieboy00's Avatar
Location: In the Short Forest , with the toads , near Camarillo.
4,427, Level: 15
Points: 4,427, Level: 15 Points: 4,427, Level: 15 Points: 4,427, Level: 15
Thanks: Gave 128, Got 173
These are what I use for my Mission 7DS surrounds and they hold them with no problem at all. Straight into plasterboard - no wood batons behind or anything like that.
Matt_C (15-11-2009)
Old 15-11-2009, 3:42 PM   #12
andrewt9763's Avatar
2,844, Level: 12
Points: 2,844, Level: 12 Points: 2,844, Level: 12 Points: 2,844, Level: 12
Thanks: Gave 18, Got 106
Used these many times to hang fairly heavy items,really good.Available off e-bay as well as other places.Spring Toggle Technical Fixings Guide - Oaktree Packaging Ltd
Matt_C (15-11-2009)
Old 22-11-2009, 8:26 PM   #13
Matt_C's Avatar
26,953, Level: 40
Activity: 50.0%
Well I had a go at fitting them and they seem fine!
I couldn't get to a screw fix, so I had a route through my drawers and found a box of Thermalite fixings;
Thought I'd give em a go, worst that could happen is they wouldn't take so I'd get some of the metal ones linked above
So I drilled the plasterboard with an 8mm bit, screwed these in with the supplied tool and then screwed a self tapper into them. Gave them a good hard pull and they didn't budge, so I hung the speakers off them, and they seem totally fine! Time will tell I guess to see if they "sag" in the plasterboard, but I reckon they'll be fine.
Only problem is the speaker wire dangling. Then I noticed the walls are pretty much the same colour as a role of masking tape So for the time being, that'll work
