| Re: Fitted suit from Debenhams (Mens)
M&S do some nice off the peg wool mix numbers for just over £100. It depends what you want to use it for, does it come with a second pair of trousers or is there an opportunity to buy a second pair? Wool mix suitstend to be easier going than man made suits if you wear daily and dry clean fortnightly.
Does it need to be fitted? It may be seen as an extravagance for fitting especially if you are perhaps a student?
Assorted gear: Panny 42TH PX70, B&W Speakers, Kef HTB 2 Sub, Linn Diskreet speakers, multiroom Sky+ HD, PS3, Tosh EP30 HDDVD, Acer iDea 500 HTPC, Sennheiser HDR-120s, network gubbins, Xbox360s, Wii, Harmony 525, 360 & One. My Av-centric home |
