Go Back   AVForums.com > Lifestyle Topics > General Chat
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Removing the Hard Drive from a Western Digital My Passport Essential SE 1TB 2.5 7hil Hard Drives and Memory - RAM/Cards and Sticks 14 29-10-2009 10:05 AM
Have to 'safely remove' NAS drive before powering off my PC? DaveHav Hard Drives and Memory - RAM/Cards and Sticks 2 23-10-2009 8:02 AM
Gallbladder removal Jenn General Chat 12 22-10-2009 5:36 PM
Removable projector bracket? Pecker Projectors 2 22-10-2009 6:19 AM
Seagate Desktop External Hard drive - Need to Remove the HD DJACID Hard Drives and Memory - RAM/Cards and Sticks 1 21-10-2009 7:06 PM
Old 24-10-2009, 9:02 AM   #1 (permalink)
Thanks: Gave 481, Got 254
Best way to remove sealant ?
I got areas around in the bathroom and kitchen that need re-sealing as the mastic/sealant is tatty and gappy.
Is there a painless way to remove the old stuff completely and cleanly ?
Pioneer KRP600A, Denon A1HDA, Panasonic BD35, Panasonic PX80, Panasonic DMR-E500, 2x Kef Ref 2.2's, Kef Ref 200c, 2x Kef Q2DS's, 2x Kef Q60's, SVS PB12-Ultra/2, Velodyne SMS-1.
Nikon D300, 18-200mm, 17-55mm, TC-14E, Sigma 10-20mm, SB900.
Flickr
Steve N is offline   Reply With Quote
Old 24-10-2009, 9:10 AM   #2 (permalink)
wiz
Thanks: Gave 31, Got 21
Re: Best way to remove sealant ?
Nope!
Just use a Standley knife, thats what I did. Be careful not to cut yourself
Panasonic TH-37PX7B, Onkyo 875 ,
Sony BDP-S350, Sky+
Front Mission 773, Center Canton CD50, Rear Mission 70DS
wiz is offline   Reply With Quote
Steve N (24-10-2009)
Old 24-10-2009, 9:47 AM   #3 (permalink)
Thanks: Gave 172, Got 635
Hi Steve
Yes - you can purchase a special sealant removal tool from any DIY store.
Dig it in one end and run it along and it lifts up the old stuff - mold and all! Works well.
Alan
Alan CD is offline   Reply With Quote
Old 24-10-2009, 10:52 AM   #4 (permalink)
Thanks: Gave 170, Got 366
Does that work on silicone?
I could easily imagine it working with acrylic and mastic - when removing that I try to get under it at one end and then tear a strip off.
But silicone clings like hell (if it was applied properly in the first place). Even if you cut it with a blade, the residue remains and clings tighlty.
There is silicone remover - I've never tried it but next time I have to remove some I might give it a go - I'd cut as much as I can and then use the remover liquid on the residue.
If the liquid can remove set silicone it must be pretty nasty stuff though, so take care.
Cheers,
Nigel
nheather is online now   Reply With Quote
Old 24-10-2009, 11:52 AM   #5 (permalink)
Thanks: Gave 16, Got 105
If you use the silicone remover (it does work) remove the thick first with a stanley knife. Also make sure you clean the area with meths or it will dissolve your new silicone
John..
27neth is offline   Reply With Quote
Old 24-10-2009, 1:41 PM   #6 (permalink)
Phil57's Avatar
Thanks: Gave 88, Got 114
The tool that Alan CD mentioned works surprisingly very well, use the tool to remove the bulk, then use sealant remover to melt any remaining, then I would suggest using a steam generator to finish.
Phil57 is offline   Reply With Quote
Steve N (25-10-2009)
remove, sealant
